Question about Garden
Campbell Hausfield Air compressor Mod. HL421500, One year old. My compressor is running but will only put out 10 Psi.
The valves are bad. Replace them with a valve plate kit from ToolPartsDirect.com.
Posted on Oct 06, 2010
How many liters of compredssor oil to fill tha compressor tank
I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
Feb 25, 2015 | Air Tools & Compressors
Campbell. Hausfield air compressor runs But shuts
It should shut off once it reaches max air pressure, if not it would explode. The question is, when the air presser drops, does it turn back on? If it doesnt, then you have a bad safety switch.
Oct 16, 2014 | Air Tools & Compressors
Max pressure 40 psi
i would say rings r gone on piston if u take out oil filler bung to see if it blowing air dat will tell the tale
Jul 28, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
I bought a HS5180 air compressor from WW Grainger. I lost the manual, and directions to install. Can you please email them to me? Thanks Jeff
Jeff, you can go to the Campbell Hausfield website, and download all of that. You can save it as a PDF file, and just print it yourself.
Apr 08, 2010 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
Jan 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
