Question about John Deere Garden
I had clicking noise on solenoid when trying to start so i changed it and still have noise. how do i test the starter?
  • 394 Answers
Take a pair of jumper cables ( assuming you have a good battery)
hook them up to the battery take Black (Ground)to the frame and touch the Red ( hot) to the terminal directly on the starter itself.
This terminal will be where the thick red wire attaches to the starter. If the starter is good it will spin.
Best Wishes,
Wayne
Posted on Sep 14, 2010
Clicking noise from under hood before it turns over. sometimes won't start, but will start when jumped. battery is good.
battery may not be good have it load tested --also alternator and starter tested---clicking would be starter solenoid trying to get starter to turn over ---check the connections at battery and starter for loose or corrosion
Aug 22, 2015 | Cars & Trucks
Tried to start car and it was starting to crank over then started getting this clicking noise. thought it was the battery connection, I cleaned the cables and posts and still got clicking noise when...
celunoid ?? SOLENOID ! Could be starter , test ! VOLTAGE DROP TESTING .
Starter Voltage Drop
What size engine ???
Starter Motor, 4.6L C1020
Lower right side of engine
Starter Motor, 5.4L C1020
Starter Motor Relay, 4.6L C166
Right rear of engine compartment
C167
Starter Motor Relay, 5.4L C166
C167
Jun 23, 2017 | 1999 Lincoln Navigator
Car won't start makes clicking noise when you turn key
The click noise is the sound of the starter SOLENOID clicking but not contacting to supply voltage to the starter motor.
Now a multimeter test will confirm if the solenoid is contacting and if so then the starter motor is faulty.
It can be due failure of the BRUSH in the motor or the commutator. If so remove the motor and confirm.
Also if the starter pinion is struck the solenoid will click and the motor may not turn.
Jul 25, 2011 | 2008 Chrysler Pt Cruiser
I try to start my truck up which is a 2003 ford expedition and it makes a ticking noise! well i jus changed the starter and its still making that noise. could it be the alternator or whats the problem?
The starting system consists of:
  • starter motor
  • starter switch, part of the ignition switch
  • digital transmission range (TR) sensor (automatic transmission-equipped vehicles)
  • starter motor solenoid relay switch
  • starter solenoid
  • starter drive
When you turn your key to start your engine, it just clicks, right? If so, more than likely this is due to a bad battery. Even though your battery may appear to be fully charged, it may have a dead cell, or worse. If you get a jump, does the vehicle start? If so, replace your battery.
Possible sources of the problem if the engine does not crank or the relay clicks:
  1. Battery
  2. Starter motor
  3. Starter motor relay
  4. Ignition switch
  5. Damaged fuse
  6. Anti-theft system
  7. Circuitry
Mar 16, 2011 | Ford Expedition Cars & Trucks
I installed a new solenoid, new battery, new spark plug. checked all my connections. and all i get is a clicking noise when i try to start the motor. could the starter be bad ? would it make that clicking...
Good morning Brian.
You need to have a current tester to make sure. If you don't have one, you can buy a cheap one for less than $10 that will get the job done.
1. Test the battery. Make sure you have at least 12 volts DC across the terminals. If not, charge the battery and retest. Even new batteries can be discharged or defective.
2. Test the voltage at the solenoid. You need at least 12 volts to each of the terminals when the key is engaged to the start position. You may need a helper to turn the key while you test the current. Failure to get current to the lower terminal on the solenoid is usually caused by a defective ignition switch or a defective/dirty safety switch. Most mowers have at least 3 safety switches. Your clicking noise is probably the solenoid engaging and is a normal noise.
3. Test the voltage at the starter. You need at least 11.2 volts at the terminal on the starter motor. If you have enough current, and the starter is still not spinning, then you have a bad starter. Sometimes a failing starter can be used a few more times by lightly tapping on the side of the starter motor with the wooden handle of a hammer. If the brushes in the starter are sticking, then tapping on the side will occasionally allow the starter to work. This is a very short-term repair. The starter will either need to be rebuilt or replaced.
Good luck.
Oct 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How can I test the starter solenoid on 1998 Volkswagen Cabrio? I remember from many years ago that you can bypass it to verify if that is the part causing it to not start, but can't remember details, and...
The loud rapid clicking noise wounds like the solenoid is working. Your description sounds like not enough battery power.
Works like this: Enough power to fire the soleniod, but when the started in engauged, not enough power to run, voltage drops, solenoid disgngauges, then process starts again...
Try external power, like jumper cables...
In answer to yoru question, solenoids have typically, two smaller power connections, and two much larger connections...The big connections are battery in and out, and the smaller ones...: one is is the actuator, and one is ingintion resistor bypass. Ususally the small connector at the 2 oclock position is the actuator.
I suggest that you bench test this starter.
Sep 16, 2009 | 1998 Volkswagen Cabrio
2000 trooper wont start!!! pulled it in the driveway shut it off then wen't to leave and wouldn't start. i changed the starter relay and still nothing. makes a clicking noise and that is it. is there a...
Sounds like the starter solenoid is working, but the starter motor isn't. If you have a voltmeter or test light, measure for light/12 volts at the motor terminal while someone tries the key. If the solenoid is what is 'clicking', but nothing at the motor terminal, change the solenoid. If you get light/12 volts, then the motor itself is in trouble.
Aug 22, 2009 | 2000 Isuzu Trooper
Car wont start...sometimes
Sounds like a bad starter solenoid, usually cheapest and easiest to replace the starter and solenoid as a unit. It is always best to check for power between the solenoid and the starter with a test light, if the solenoid clicks but the test light doesn't light up you have found the problem in the solenoid.
Apr 28, 2009 | 2003 Pontiac Grand Am
Pickup wont start
well you can short over the starter and see if it starts. honestly i would remove the starter and take it to your local autozone. they will check it for free. also check the start solenoid. they have a tendency to cause the same effect.
Jan 14, 2009 | 1999 Dodge Ram
Car wont turn over
try putting a new starter.donny
Jun 12, 2008 | 1983 Ford F150
Garden Logo
222 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
