Question about Canon imageCLASS D880 All-In-One Laser Printer
I have got a CANON ImageClass MF3240, and I can not get it Started, it was working perfectly fine, but now it won't even start or light a led from the front panel. I've checked the power cord with a multimeter and also the power inlet of the printer, as a Result, I had everything powered right. It seems like the power won't go to the START button, so it can be turned on. How can I get this fixed?
  • 1 more comment
  • panchoga1209 Sep 15, 2010
    Hi Steve, I had checked the fuse already, it is a 250V 10A. And when the power is on, 120VAC passes through (also measured with multimeter) . I'm not sure if the power supply board could be the one causing the problem, because whenever is powered on, I don't have any voltage in the other boards. Or could be that they need to wait until the START button gives them the power signal to turn them on. I've also checked the Control Panel board, specially the buttons, to see if one of them was not working right, or could be open all the time, but all of them are working good.
    Appreciate, thanks
    Hi, the fuse is perfectly fine, I've checked it, and measured 120VAC when powered. Thanks for the info, I'm still looking for the component that is not letting the printer work at all..
  • panchoga1209 Oct 05, 2010
    No, I don't see any burnt track at all in the Power Supply board or boards.
    President:
  • 2,185 Answers
If no led light would turn on, try to use other power cords. If it still does not light us a led, then this is already a hardware problem with the printer as the power supply went defective. You need to have that changed. Contact your nearest Canon authorized service center for repair. If this unit is still under warranty, the you can save cost.
Posted on Sep 16, 2010
  • Canon Master
  • 3,083 Answers
This sounds like a fuse, hopefully. You will have to take the unit partially apart to get to the power supply board to investigate. Not sure if these manuals will help you, or if you already have them, but here is a site to download free manuals:
http://www.generalmanual.com/Printers/Canon-imageCLASS-MF3240-Laser-Multifunction-Printer.htm
If you have too many problems checking this out, you may need a service manual, and you might check with canon support:
http://www.usa.canon.com/cusa/support/consumer
I couldn't run down a service manual on the net, so contact Canon if you need one.
Good luck, and hope this helps.
Posted on Sep 15, 2010
  • 1,675 Answers
Hi, i am glad to see you have done the normal checks with the volt meter, but there is an internal fuse for these, you will have to gain access to the power supply inside, on or around the power supply should be either a 3 or 5 amp clear fuse, these are not your normal type fuses like you get in the plug, but these are slightly longer and clear glass........do not except this answer yet please, no thumbs up till you fix the problem, then can you thumbs up and accept the answer thanks...............
Posted on Sep 14, 2010
  • steve morris
    steve morris Sep 15, 2010
    hi no ,this should defiantly have power up to all the boards in the system, this actually does sound like the power rectifier may have blown is the board showing any signs of burnt tracks? or burnt soldered connections?
  • steve morris
    steve morris Oct 05, 2010
    hi again well in that case you have 2 items that may have gone, first the DC control pcb, which if you ask me is the culprit, or the HV transfer pcb, which may also be at fault as these are both power regulated pcb's that send power to the system, you might be best off asking a canon engineer about these, as there are so many different types i would not want you to order the wrong part, but i think you will find it was the first one, the DC control board pcb at least this gives you some idea what you will be asking them and if it is possible that , that could be the cause of your fault...
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: I have got a CANON
Hi
Please check this link bellow to have a general idea when a printer wont turn on:-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpd05351
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 08, 2010
Canon imageCLASS MF3240 All-In-One Laser Printer Downloade
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
May 12, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Canon MF3240 firmware update failure
YOU THEN NEED TO REINSTALL IT BECAUSE YOU CANT ROLL BACK THE FIRMWARE
Mar 29, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
I bought a new Canon image clas MF3240. I installed the software but it does not print. How do I print?
Make sure the software is installed correctly. Add your new printer on your hardware in computer to make them paired perfectly.
Jan 05, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Refilled cartrige on MF3240. Says out of toner. How do I reset it?
Hi there
This is because of the refill you can try going to your menu and then reseting it, the old chip still see that it was emty.
All the best Pineworks
Apr 28, 2010 | Canon MF3240 imageCLASS Laser...
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Canon MF3240 error code E000
change ink, if problem continues change scanner
May 17, 2009 | Canon MF3240 imageCLASS Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
94 people viewed this question
old marine
old marine
