I've an old reflecta diamator AF delux dia projector and I will convert my old framed dias to digitalized ones. Can I make a conection between a laptop and this dia projector?
SOURCE: I HAVE INFOCUS LP600 PROJECTOR
Replace 4, 100 mfd capactor and 1 4.7mfd capactor. on the power supply board, if still nedd help call me at 408 685-7901
thanks
Shakeel
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: i need fuel line routing for mcculloch fr2.0 chainsaw
primer bulb... long barb goes to fuel tank pick-up.... short goes to carb.... make sure the new tubing is safe for the damn ethanol fuel and that it fits snug thru the tank or it will leak
Posted on Aug 18, 2009
Testimonial: "thanks"
  • 105 Answers
SOURCE: require cct dia for Jewel ac adaptor model JS-12060-3K
Ok this is weird but ill point you the right direction.
At radioshack there should be a good supply of fuses and electronic resisters. You may find one at a TV repair shop also . Or you might get them too send you one from web purchase.
Posted on Oct 18, 2009
Raditronic
  • 196 Answers
SOURCE: prende dos dias y dos dias no prende asta que se
trata de resoldarle todas las resistencias y piezas que veas con soldadura fria.si hay piezas con soldadura fria ellas se mueven y no hacen contacto, los sony's padecen mucho de eso.espero esto te ayude.
Posted on May 06, 2010
  • 58 Answers
SOURCE: We laid a ( fairly new ) hot cookie sheet atop our
The manufacturers warranty period is only through the first year. So unfortunately you either have to live with it or replace it.
Posted on Sep 18, 2010
Where to put silver colored spring very small dia.
It may be out of the wrist pins on the band or it could be a battery spring.
Jun 20, 2016 | Casio Aq47-1e Analog/digital Watch
What size are the starter bolts on a 2002 dodge stratus. i broke one and it seems longer than the other
You mean metric diameter & thread pitch?
You will have to mic the diameter & convert
to metric or just match up at a store
As a guess only--dia may be 1/2 "or 12mm & length say
2" or 50mm
.0395 is (1) mm
Whatever you measure dia or length wise, you
divide by .0395 to go to metric
They heat treated bolts,not a Home Depot
chinese item
Aug 13, 2014 | 2002 Dodge Stratus
Connect Nikon D60 to Opticron Scope
You should be able to buy an SLR adaptor from most Telescope retailers Try asking "Telescope House" if you can't see what you need (link below).
https://www.telescopehouse.com/astro-imaging.html?cat=154&p=1
Nov 26, 2017 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
Jun 26, 2010 | Robot Coupe CL50 Food Processor
No funciona
BUENO no se que es lo que no funciona per muchos aparatos hoy en dia funcionan un dia oh no funcionaron del todo ...es necesario cargar toda la noche antes de usar cualquiera que usa bateria ...lo mejor es buscar otra cosa que muchos usan asi uno esa seguro que funciona..
Feb 04, 2010 | SanDisk Sansa e130 MP3 Player
Oh and what do i
TORQUE VALUE CHART
7/16" dia. 50 to 60 lb-ft
12mm dia. 70 to 80 lb-ft
1/2" dia. 80 to 90 lb-ft
5/8" dia. 110 to 125 lb-ft
*Use this chart to get correct torque values for each size wheel stud. I hope this helps and don't forget to rate my answer.
Feb 01, 2009 | 2002 Chevrolet Malibu
343 people viewed this question
k24674
jasbo
jasbo
