Question about Husqvarna 23 Hp 48" Deck Yard Tractor
My Husqvarna gth 2654 the deck belt is loose. How do I tighten the belt tension rod
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
SOURCE: I have a Husqvarna YTH 2348 the deck anti sway bar
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Posted on Jul 04, 2009
MIlfordPrint
  • 90 Answers
SOURCE: belt diagram
You can find the diagram here:
http://lawnandgarden.manualsonline.com/ex/thread/view/idThread/340092
Posted on Aug 03, 2009
daneinwv
  • 124 Answers
SOURCE: Hi, Just replaced the drive belt on a Husqvarna
My name is Dane and I am going to help you solve your problem.
I looked up your mower and I believe you should be using drive belt# 5321701-40. That is a 112" belt. Here is a link to the parts manual and a drawing of the belt routing. As long as that is the belt you have, and replaced it correctly it should be fine. You are correct, when you put the mower in gear, the pulley system will put more tension on it.
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2003/HIPL2003_1063048-61.pdf
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 05, 2010
Testimonial: "Thankyou Dane, You are a true proffessional!"
I need to know the placement of the deck belt on my husqvarna mower 26k54t. I think I keep twisting it the wrong way, which pulleys need the flat side of the belt on?
https://www.partstree.com/parts/husqvarna/mowers-lawn-garden-tractor/gth-26k54t-96043001101-husqvarna-garden-tractor-2006-03/mower-deck/
Sep 09, 2016 | Husqvarna Garden
Will the transaxle from a Husqvarna GTH 2448T Hydro Gearr part # 316-0610 bolt into a Husqvarna LGT 2654 that currently has a broken axle in a Tuff Torq transaxle
Yes, the axle will fit the frame, but the pulleys and idlers will need to be set up. There is no cross reference chart so you would have to create the belt routing by trial and error. Belt length would also have to be determined.
Aug 07, 2016 | Husqvarna Garden
Parts diagram for Husqvarna GTH2654 riding mower
go here and find yours,you need more info for the right one,i would of got it for you,but,i need more info too Model Search Results for Husqvarna GTH 2654 PartsTree com
Apr 20, 2015 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Model 2254 deck belt jumped loose, need diagram as to how it winds "top view"
hi there senator359
pauly46 here
please find web site for a manual that has belt roueting in it
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_O0802053.pdf
it is lgt2654
go to web site down load and print
here is husqvarna gth 2254 web site for diagram
http://www.partstree.com/parts/?lc=husqvarna&mn=GTH+2254+XP+(96023000201)+(2005-06)&dn=86020023
check them both out
let me know if helps
dont forget the thumbs rating
cheers pauly46
Jul 08, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Can you email the mower(cutting belt) diagram for the Husqvarna LGT 2654
hi there pauly46 here
check out this web site
http://www.partstree.com/parts/?lc=husqvarna&mn=LGT+2654+%2896043003600%29+%282007-05%29
or take a look at this site
here is web site for lgt 2654 owners manual , it has belt routing , and deck installing / removing instruction in it - quite helpful
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602053.pdf
cheers pauly46 hope it helps
Apr 09, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Belt diagram
Aug 03, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a diagram to install a drive belt for this tractor
I need the model number under the seat to get you a diagram.
Jun 12, 2009 | Husqvarna Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
422 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
