Question about Broan-NuTone CV353 Central Vacuum
Motor unit blows dust and dirt out thorugh the exhaust port
How to clean/lubricate bearings on Dirt Devil motor?
If you know some one with compressed air blow out all dirt particles best as possible then get a 3 in 1 oil or sewing machine oil drip along the motor shaft and turn by hand you will be able to free the difference once lubricated it should only take a few drops per side . let set for awhile and repeat . then put her together and see if motor speed returns to normal . also check turbine wheel for slipping on shaft.
May 01, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
Dust is blowing out the front vent.
If dirt and dust are blowing out anywhere that they shouldn't be, it's a sure sign that something's plugged farther on up the line. You'll need to disassemble the unit and clear the clog before anything will go through to the dirt cup. Also, as long as you're going to be taking it apart, check all the filters. This is a notoriously neglected part of bagless vacuums, and a very large part of why they start to lose the initial level of vacuum power. Clean the ones you can clean, replace the ones you can't. Walmart and Meijer's are a couple of places where you might find replacements.
Apr 20, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Clean tank indicator keeps going off after tank has already been cleaned
The Roomba is noted to cut out operating correctly. Remove the housing and blow out dust from all circuist and any dirt and dust inside the entire unit. It should work correctly afterwards
Jul 24, 2010 | iRobot Scooba 380 Robotic Vacuum
It is blowing dust out of the motor
If this is a bagless machine, then the problem is that the really fine dust that you are picking up from your floor is so small that it is going through the filter and dust cup and building up in your vacuum motor. When enough build up collects, then it starts to blow it out the exhaust. I would bet a paper bagged machine for the long run. They are cleaner,
Nov 28, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
My Oreck XL is very dirty inside on fan and the motor runs very loud. It is not clogged.
These units are called dirty air units because the dirt literraly runs thru the fan attached to the motor and is blown into the bag. Most newer vacuums are called clean air because the filter bag is in the path, and the dirt is sucked into the bag, never reaches the fan or motor.
I'd say if it is that dirty, may be a fire hazard, and you may have worn out the seals on the part down at base that pivots to a point that replacement is necessary.
(I'd blow out the dust and keep using if it was me, and then check again in a few weeks, before I replaced. But I like living dangerous.)
Jun 22, 2009 | Oreck XL21 Bagged Upright Vacuum
Motor runs fine and hose not clogged will not pickup dirt
This may sound silly, but have you checked the belt? A lot of Eureka vacuums use the vac motor to run the brush, and if the brush is not running the vacuum won't pick up. Another thing to check is the condition of the fan blades.. if they get worn they will push air out of the exhaust ports, but not push enough air to pull the dirt into the vacuum bag. Another thing to check is the length of the bristles on the brush... you can change a lot of the bristle strips and save the cost of a whole brush roll.. All of these fixes are under $10.00 (Belt: $1-2, Brush Strip $3-6, Fan $5-10) at most places.
Jan 19, 2009 | Eureka Vacuums
How do I change the belt for my dirt devil vacuum cleaner? It blows out dust.
To change the belt, take off the bottom plate, the belt runs between the brush roll and the motor shaft. But if it is blowing out dust, you may have a clog in the dirt inlet by the brush roll, or in the hose.
Mar 23, 2008 | Vacuums
Broan-NuTone CV353 Central Vacuum Logo
116 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
