Question about Craftsman 20 Hp 42" Deck Lawn Tractor
My crftsman DRM 500 lawnmower, I put it in forward and give it gas and it won't go anywhere
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
My son put oil in lawnmower gas tank
Drain as much as you can out. It won't hurt thing. May smoke a
for a little bit.
Oct 05, 2012 | Toro Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
I have a 1/2 hp crftsman 41A4315 garage door opener. I changed the gear and now it won't close all the way. It started going down and reverse back up
your chain is in the wrong position, unhook the chain and run the door opener so it is in the down position, then reattach the chain and make the adjustments as needed on the up and down screwes located on the side of the unit. good lick
Jun 21, 2012 | Chamberlain Sears Craftsman 950cb 953c
2004 Cadillac CTS won't go into gear -
I will quess that there is a 90% chance, you will have to
pull the transaxle & have it rebuilt
From here forward, you change your trans fluids every three
years ,along with the power steering.That will fail next.
Jun 01, 2012 | 2004 Cadillac CTS
Is there a way to take the 100 free eBooks that come with the eReader off of the Libre Pro and put on computer? I don't want to loose them, but I want to make room for more ebooks that I will read first. ...
1 The the Libre Pro supports PDF (Adobe Digital Edition DRM/non-DRM), TXT, FB2, EPUB (Adobe Digital Edition DRM/non-DRM), MOBI (non-DRM only), PRC (non-DRM only)and RTF electronic book format.source:http://aluratek.com/libre-ebook-reader-pro-black2 60 Sites to Download Free Kindle Books if you download free kindle Books protected from kindle DRM from Amazon, you can download Ultimate Convert. Ultimate eBook Converter, helps you reading books anywhere, include the best eBook Converter + DRM Removal functions.
Sep 02, 2010 | Aluratek Libre eBook Reader Pro
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Lawnmower will start but will not stay on
I had the same problem, what you need to do is adjust your throttle. To do that you there is a switch right in front of the filter. If you are looking right at it pull it all the way to left. If this dosen't work then check the springs that are connected to that switch they have a bad habit of coming loose. I had to replace all of my springs. Hope that helps.
Apr 15, 2009 | THQ The Lawnmower Man
Where are the fuses on a crftsman 42in hydro 15.5 hp
one fuse on right side under fuel tank
Oct 03, 2008 | Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
357 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
