Question about GE Refrigerators
Need SXS 21-22 Black Maxs.663/4" H Prefer at least water in door
Sxs21
SSS
Posted on Sep 23, 2011
Whirlpool ref. panel light will not stay on. how do I make it stay on
Sounds like a machine operating ok. Buy a nightlight or contact the manufacturer for a user manual.
Jun 01, 2015 | Whirlpool ED5FHEXVS - Ref Sxs 25 - Sxs...
Water,ice dispenser only dispenses ice
The switch in the door could be bad. the water side of the water valve could be bad. Sometimes especially in GE SXS refrigerators the water tube freezes in the door. You will have to see if you are getting water to the door by disconnecting the couple under the freezer side and tap the water dispenser if you get water there then the tube is frozen and you will have to thaw out the door for a couple hours. A slight possibility is the water reservoir in the fresh food section behind the crisper could be frozen. Again you will have to thaw it out.
Aug 15, 2014 | Refrigerators
Water at the bottom of the refrigerator side
Without knowing the model I assume you are talking about a SXS. If you have water on this side it may be coming from the water reservoir if you have a water dispenser on the freezer door. Some SXS refrigerators have a quick cool compartment and these usually have a small refrigerator coil that can build up with ice and if the drain is blocked water can run under the crispers.
Aug 13, 2014 | Refrigerators
I have a Sterling 1500D Shower door and I need to replace hollow gasket at the bottom of the door. Where do I purchase this from???
It sounds like you need the sweep or seal that keeps water in the enclosure. You can buy these items, which are inexpensive and usually easy to install yourself at www.technologylk.com Technology LK carries a comprehensive range of shower door gaskets, seals and other hardware. If you have any questions about exactly what you need and how to install it, you can contact the company at www.info@technology.com or call them at 888-663-9830.
Jul 10, 2012 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
Ge sxs model GSH25KGRB BB. We have water and ice in the door and when using the water in the door, the water doesnt stop running out even after you pull glass away and we have started to see water frozen...
your water valve might be bad it locate behinde the fridg on the bottom you need to pool out the pip from it to see if it still leak..
contact me at www.911servicetoday.com
Dec 30, 2009 | GE GSH25KGR Side by Side Refrigerator
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore model 88892 sxs refrigerator started to leak water on the bottom underneath of refrigerator. I cleaned all lint and debri underneath, but still water coming out on floor. Dont their suppose to be a...
There is a tray that is in the bottom, remove the cover thats located just under the doors in front. You will see it most of time black in color and it will be easy to pull out be careful for it will be full. Its from condensation most the time in the summer this happens really no problem. if thats not it check the ice maker water supply line that could be it also.
Aug 09, 2009 | Refrigerators
Ice Maker will not work. Water is not being pumped from the valve up to freezer compartment, however water is going to the door water dispenser. Appears no power to the valve. Any suggestions?
if this is a sxs fridg. you have two valves one for door water and one for ice maker.. you need to verfi this and then go from there... it sounds like a bad water valve..
Jul 29, 2009 | Refrigerators
Refrigerators Logo
561 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
