Question about Mavic Ksyrium Elite Wheelset
I have 2006 mavic Ksyrium elite wheels having done less than 500 miles. The rear cassette is certainly tight enough but i can rock the cassette by about 1-1.5mm by holding the 25 ring? We've opened it all up and it's immaculate - We've retightened but the play is still there. Is this play normal? I have other wheels with much more milage and no play? Cheers, Steve.
    Genius:
  • 1,788 Answers
Could be the sealed bearings, just like a car, nothing gets better by itself if it is loose. With expensive wheels, take it to a shop unless you know what you are doing and have the proper tools. Why mess it up so that no one can fix it? Yes, I own 4 large bike stores and sell over 5000 bikes a year, anywhere from $325. to $12,000 models, so I do speak from experience. People are always amazed that the bike sometimes needs a tune up, Well, your car needs it too, but somehow a sewing machine or a bike shouldn't have to? Hummmm, interesting.
Take it to your dealer and let him advise you, this is not a do it yourselfer. Don't be surprised if you need a new chain, they stretch.
Posted on Sep 14, 2010
Broke spoke on mavic kyserium sl can't ride bike, miles from home
being a french bike I don't know who can get you a replacement , but if its just a spoke or two,, wind the broken ones around so they don't rub on the fork or frame, and I'll keep looking , so check back, wow those are expensive,, heres a link
http://www.amazon.com/Mavic-Ksyrium-SL-Bicycle-Rim/dp/B0034L0872 Is it the front or rear ? heres a rebuilt one for less http://www.competitivecyclist.com/product-components/2011-mavic-ksyrium-sl3espremium-wheel-rebuild-4051.1849.1.html
Jul 15, 2011 | Mavic Cycling
Wheel does not stay true
Check if your spoke are tight enought, sometimes if the spokes are loosen the wheels will bent really easy.
May 18, 2010 | Mavic Ksyrium Elite Wheelset
Cant put my mavic back together properly
It sounds like you lost the washer that sits between the bearing in the nose and the freehub bearing. If you lose that washer, when you re-tighten the axle, the two bearings will bind and prevent the freewheel from spinning easily.
Take your freehub off again and see if that washer is there. If it isn't, you'll have to get a new one and replace it. It's easy to lose that thing if you don't know it's there when you take the wheel apart, because it'll just fall out.
When I reassemble those wheels. I thread the drive-side axle through the freehub body, then place the washer over the axle on the inside of the bearing, then thread the axle through the nose.
Also note that if your freehub seemed loose, it probably needs to be replaced. The FTS-L freehub body used on the Ksyrium wheels uses a nylon bushing as the friction interface to the nose, and this bushing wears down over time even with good lubrication.
Feb 10, 2010 | Mavic Ksyrium Elite Wheelset
HELLO, I HAVE A DURA ACE 7900 MODEL CASSETTE AND WOULD LIKE TO PUT IT ON A KSYRIUM SL RIM, DO I HAVE TO PUT THE SPACER ON IT BEFORE THE WHOLE CASSETTE GOES ON? THE CASSETTE IS A 12-25 GEAR.
In my experience with Shimano cassettes on Mavic wheels, the answer is "yes" but i had a mountain wheel and cassette. The only way to know is to put it on and see if there is slop in the fitment. If there is, then you have your answer. i also had this problem with Mavic: i had to adjust the high and low settings on my rear derailleur because of the awkward spacing of the Mavic freehub. Just something you should be aware of in case you have difficulty with shifting after the install. By the way - although they are inferior cassettes, SRAM cassettes seem to fit Mavic freehubs better.
Regards,
matt
Sep 14, 2009 | Cannondale Cycling
Noise from ksyrium back hub
The mavic hubs need to be disassembled and cleaned/lubed every few thousand miles. I suggest you take it into the local bike shop to have the work done unless you are a fairly good mechanic. It is rather simple to overhaul but it could be a headache if done incorrectly.
Hope this helps!
Jul 09, 2009 | Mavic Ksyrium Elite Wheelset
Noisy Rear Mavic Ksyrium Hub
Sounds like a road wheel with a worn FTS-L freehub body. You'll need to have it replaced.
What happens is that the nylon bushing wears, causing there to be play between the freehub and the nose of the wheel. Once there is enough play, the freehub can actually vibrate against the nose, causing noise and friction - which is why you see the chain slacken. This is commonly called the "squeal of death," meaning it is an indication that the freehub body is "dead."
A new FTS-L freehub body should be about $50-60 and shop shouldn't charge more than about $20 to change it out. Just be sure to tell the shop one very important thing:
"Do not lose the metal washer that sits on the axle between the outer bearing of the freehub body and the outer bearing of the nose of the wheel!"
This is so incredibly important - but time and time again, shop mechanics will lose this washer before they reassemble the wheel, causing a series of nightmares with the wheel.
Jun 09, 2009 | Mavic Ksyrium Elite Wheelset
Mavic Ksyrium Elite Wheelset Logo
493 people viewed this question
Top Mavic Cycling Experts
Eric Hidle
Level 1 Expert
Michial Gueffroy
Mack Baxter
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
