Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
GE Profile 23.6 Cu Ft, Model # TFHW24R.... What would need to be replaced for doors to close more easily?
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
Posted on May 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: TFX25PR TFT25 PR GE Profile 25.2 cu
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Posted on Jul 28, 2009
My ge profile microwave model pvm1870sm133 is not working properly. when you open the door the cooling fan turns on
Unplug and cease using this as you are exposing yourself to electro magnetic radiation. The door switch may have failed, you will need to disassemble the front panel to access the switch which is located within one of the holes that he door's hooks insert into and depresses to inform the control board the door is closed and is safe to operate.
Dec 22, 2013 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a GE side by side refrigerator (Model #GSL25JFXLB and the doors will not close all the way
Leveling the refrigerator so that the doors close easily is one of the most important ways of getting the doors to work properly. Here is a link to a Profile/Artica Service Manual Go to page 24 through 26 where the manual explains what you need to do to get the doors to open and close properly. If you have questions I will be here to answer any questions you may have, Thank You Sea Breeze
Mar 09, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
Door Doesn't close on GE Profile PDS20SCRALSS
Check for long items, too big to fit in the fridge.
May 04, 2017 | GE Profile PDS20SBSRSS 30" 19.5 Cu. Ft....
Model TFHW24R the refrigerator is not cold and now the freezer is getting warm. i've cleaned the coils, checked the door switch and unplugged it for 30 minutes. Refrig only gets to about 60 degrees.
First open the freezer and touch the back panel of the freezer if you feel any frost then you have a defrost issue until you can get your serviceman out their this weekend shut off the frig and remove the freezer items get you hair dryer out and thaw the freezer back panel it will take sometime to do so, it would be easier to see just how much needs to be done if you can remove the rear panel then once done it will happen again but (I prefer it to be failed) so I can rule out any and all failings and a serviceman can repair it.
Apr 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
267 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
