Question about Pasquini Livietta Espresso Machine
Hi My name is Tony Di Cicco I purchased a Livietta T2 Espresso Machine on May 20th/09 and as I was cleaning the Filter Screen I discovered thhat the Adaptor Disc is all cracked, need I to order this part? I also have a picture of that part can I send it to you via emailo?
  • tcicco Sep 14, 2010
    Thanks for your Help it was greatly appreciated.
    Regards
    ]Tony Di Cicco
  • 268 Answers
Hi, Is the machine still under warranty? If so you may consider bringing it back. Otherwise they sell paets on the Pasquini site -- not sure the one you are looking for is there but you can also contact them. http://www.pasquini.com/ Hope that helps.
Posted on Sep 14, 2010
Hi, the on off button on my machine is falling can purchase a replace.thankyou tony
Hello Tony,
I understand that you are having a problem with your Breville espresso machines power button. I have located the part for you if you would like to purchase the unit its cost is $5.49 and the site has a blow up of the hole unit that you may want to use to disassemble the unit here is the site http://www.ereplacementparts.com/switch-assembly-power-p-629412.html
Thank you for choosing FixYa.com
Justinbur167
Jun 04, 2011 | Breville Die Cast 800ESXL Espresso Machine
I do not get any water when I push any of three coffee choices. Makes steam and hot water just fine.
First thing I would check is the screen in the group head make sure it is not blocked. Remove and press brew button, if water flows then clean screen. Easiest way is to hold it over an open flame, the coffee will burn before the metal does. If water does not flow then you will have to back wash machine and or descale.
Feb 02, 2011 | Pasquini Livietta Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
No steam at frothing station. may be blocked. how can i repair myself??
First check the holes in the nozzle of the steam wand, if they are not blocked then remove steam wand and see if water from the faucet will flow through, if yes then problem is in the machine where the tube connects to the boiler.
Nov 23, 2010 | Pasquini Livietta Espresso Machine
I need a new water reservoir part for my machine where do I find one?
You can order on line or call them. I get parts here all the time. Great service too.
K
Oct 05, 2010 | Pasquini Livietta Espresso Machine
Our Rancilio Silvia is producing really bad tasting coffee of late...my husband thinks that it is old water but I think it may have something to do with the fact that it has been leaking from the steam...
Hi
More than likely its you brew head screen. Coffee will build up on the top surface and turn rancid after awhile. Remove the screen(its either a screw or bolt that holds it on). I like to remove everything and turn the machine upside down on a towel. That way I can see what I am doing. Clean everything even around the brew head gasket. This gasket needs to changed every year for best sealing of the portafilter. Buy 2 because they always fail on Friday when you have a party on Saturday.
Soak you brew head screen in hot water with a pinch of automatic dish washing detergent or espresso machine cleaner. Use a tooth brush to remove the crusty burnt on coffee residue or just buy a new screen. Clean this screen every 6 months because they should last the life of the machine.
Nov 13, 2009 | Rancilio Silvia Espresso Machine
No coffee comes out - button on: It beeps
This is confusing to me. This is called priming the pump and not releasing air.
The noise you were experiencing could be from the grind of your coffee is too fine not allowing proper water flow. Remove the portafilter/handle, push brew button - and if the water comes down like rain, there is nothing wrong with the machine - it has to do with the grind, and your grinder may need a adjustment.
If you have a problem with a Pasquini machine, I'd recommend only relying on authorized Pasquini service centers.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jun 28, 2008 | Pasquini Livietta Espresso Machine
No steam - steam jet does not heat
just clean the valve...
u wi get fixed sir..
Apr 21, 2008 | Pasquini Livietta T2 Espresso Machine
Pasquini Livietta Espresso Machine Logo
61 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
De Brewerz
De Brewerz
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
