Question about Xerox WorkCentre M128 Copier
How do I change the default tray on our Xerox Workcentre 7328. It won't allow default settings at the moment, and all print jobs are being sent to Tray 1 instead of Tray 4.
  • 33 Answers
Log in as administrator. Press "key" button and enter pass code 1111. You will find the settings quite easily and can change them.
Posted on Sep 15, 2010
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Xerox 7328 printing lighter image
Does this occur both when printing and copying? or just when printing?
We encourage you to use our knowledge-base as well!
http://mrc360.com/XeroxKnowledgeBase
We at MRC are thrilled to be able to offer ANYONE the new NetSync+ contract. For just $25.00 per month you can have complete coverage of up to 3 printers/scanners/MFP's! We will assist with loading drivers, troubleshooting print jobs or training users; all remotely, from the comfort of your office!
Please contact us for more information!! patrick@mrc360.com
Feb 09, 2014 | Xerox workcentre 7328 13r624 13r00624
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
Dec 28, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
We changed the paper type in tray 3 to high gloss and need to change it back to regular paper but we can't remember how.
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
Oct 20, 2011 | Xerox WorkCentre 7328 Multifunction laser...
I cannot use cover pages with my workcentre Xerox 7328 since i got windows 7
update your print driver to latest version and make sure you select Win 7 (32 or 64 bit) as OS if not already selected. once loaded, rt-click on printer, select Print Prefs, goto Advanced Tab, expand Paper selection and Enable Banner Page.
Jun 10, 2011 | Xerox WorkCentre 7328 Multifunction laser...
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
How do I clear the completed print job list on the Xerox workstation 7328
To delete ALL print jobs:
Turn OFF. Let it power down all the way, wait 10 seconds.
Hold Energy Saver + 6 + Stop.
Turn ON.
Release buttons after Xerox logo appears.
Nov 22, 2010 | Xerox WorkCentre 7328 Multifunction laser...
My xerox workcentre 7328 has just flagged for replacement of the toner drums. Can I still print until they arrive?
By default, after the drum counter has lapsed you still have several thousand copies left before it will actually cease copies. There is no risk or danger to your equipment by continuing to run jobs, it's just a service message alerting to replace the drum soon.
-David.
Nov 03, 2010 | Xerox Office Equipment & Supplies
Xerox WorkCentre M128 Copier Logo
1,049 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
