Question about Samsung Washing Machines
I have a samsung sensor quick P801 800 front loading washing machine. It is giving me error code E6. Is this an easy fix?
  • 3 Answers
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
My Samsung washing machine, front load, showing E3 error, can you help? Thank you
Samsung Washing Machine Error Code 3E = Motor Drive Error or Hall Sensor ErrorWhen your Samsung Washing Machine shows the error code 3e, the most common reason is because of a "wire harness or wiring connection is loose, not connected, or wiring is damaged". Checking the wire harnesses on the motor, hall sensor, stator, control board etc, will usually result in finding a faulty wiring connection or bad wire hareness. Reconnecting or replacing the wire harness or wiring will fix the washer and clear the 3E error. See more troubleshooting info below...
how to fix error code 3e on samsung washing machine Google Search
Mar 23, 2018 | Samsung Washing Machines
Daewoo front load error code E6
daewoo washing machine error code e6
Feb 11, 2018 | Daewoo Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
Lg top load washer e6
Oct 21, 2012 | LG WFT1071TP Top Load Washer
Samsung P801DWNXRC Frontload washer displays E6 error code
Apr 28, 2009 | Samsung WF337AA Front Load Washer
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
2,116 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
