Question about Magellan Maestro 4040 GPS Receiver
Internal battery not being charged - Magellan Maestro 4040 GPS Receiver
    President:
  • 1,111 Answers
He following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Posted on Sep 21, 2010
My canon Vixia HF100 keeps resetting- the clock, my preferences etc. I assume there is an internal battery that needs to be replaced, but i don't know where to begin. How do i change it?
The external battery is what charges the internal battery. I presume that this occurs when the external battery is being charged out of the camera. If this is so, you may want to consider getting a spare battery, so that there is always a charged battery in the camera.
May 29, 2017 | Canon Cameras
Kodak m1063 not holding date and time
There is an internal battery in most cameras that is charged by the Lithium Ion battery when the camera is in use. If the camera is being used and the Lithium Ion battery is fully charged and yet the time/date is not being stored then there is probably a problem with the internal battery
Sep 15, 2014 | Kodak EASYSHARE M1063 Digital Camera
How do I charge a nikon clock battery
The clock battery is internal and cannot be removed or replaced except by a technician. It is recharged by your regular rechargeable battery, so there is no separate charging procedure. If you find that your clock and other permanent settings are being list when you remove your regular battery for charging, then it's an issue with the internal battery and should go to repair.
Aug 12, 2014 | Nikon D50 Digital Camera
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
Oct 19, 2011 | Canon G12 Digital Camera
Can you charge the 1440 using a usb to the computer?
For the software version: In the menu go to "Product Information" you will find it there.
If your GPS receiver has power pin port and a USB port the internal battery cannot be charged using your computer. You must use the supplied vehicle power adapter to charge the receiver's internal battery.
If your GPS receiver only contains a USB port it can be charged by your computer however we recommend using the supplied Vehicle Power Adapter.
Charging the internal battery using your computer may take up to 12 hours. Charging the internal battery using he supplied Pehicle power Adapter takes 4 - 6 hours. The receiver can be powered on or off while charging.
Most other answers can be found below.......
http://magellangps.helpserve.com/index.php?_m=knowledgebase&_a=view&parentcategoryid=68&pcid=6
Feb 17, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Loox 710 will not turn on or charge, i have been charging the battery for over 24 hours, and still nothing, is there an internal battery and how to i get to it to change it
If you have the right charger with cable and can plug in at the bottom of the LOOX,then You can use the 710 WITHout removal battery (LiON). The internal backup battery
will charge then The internal backup battery is NiHm and will sometimes NOT recognized by WindowsMobile. P.lease check several times energy state in WindowsMobile
(green bar shows percentage). If you have craddle and charger you can try to charge removal battery in slot behind plastic shield.
If you not have the rigth charger try to lend a ASUS MyPal A serie (A632 aso) it will fit
Apr 04, 2009 | Fujitsu Siemens Loox 710 Pocket PC
How to power battery up propery for use
Hello sarajjd, your description indicates correct operation. The internal battery will require charging overnight. I will need Mgfr, make & model to confirm.
Nov 03, 2008 | Electronics - Others
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Symbol RF MC9060S - Internal Battery is dead
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Jul 06, 2007 | Laser Symbol Technologies MC9060S Mobile...
Magellan Maestro 4040 GPS Receiver Logo
66 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
