How to open the case of a Gateway NV52 Laptop computer to replace the AC power plug?
  • 4,323 Answers
Hi
To disassemble you'll need to remove the screws at the back of your laptop. Please check the video for disassembly of your Gateway NV52 laptop--
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 14, 2010
Gateway nv52 laptop cays corrupt registry stuck in recover mode
start computer and lunch startup repeir. you see windows is loding files and you see blue screen read and click next computer will start now
May 31, 2013 | Gateway Computers & Internet
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
Why won't my gateway MD78 power on?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
How to retrieve files from a hardrive on laptop that will not work
One way to do it would be first remove the hard drive:
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52faq4.shtml
Then use a hard drive dock such as this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071) to connect via USB to a working computer where you'll be able to access your files.
Jan 13, 2012 | Computers & Internet
My laptop is a gateway Model:MC7801u. I have had it since 2008 and have had constant problems with the ACadapter and battery. It randomly decides not to charge my battery and then my battery dies and the...
Some people have successfully reset the charging system with the following procedure:
  1. Shut down the computer
  2. Close the lid
  3. Unplug the AC adapter
  4. Remove the battery
  5. Plug in the AC adapter
  6. Open the lid and turn on the computer
  7. Log in to your user account as usual
  8. Shut down the computer again, and close the lid
  9. Unplug the AC adapter
  10. Put the battery back in
  11. Plug in the AC adapter, open the computer and start up again
The battery should now charge normally. If this process needs to be repeated any time soon, the small clock and parameter backup battery inside may have gone bad. I don't know where that is in this particular model. In some designs, it's accessible from the wireless card or memory compartment; in others it's somewhere under the keyboard.
Charging failure can be the result of a broken cable in AC adapter, often caused by yanking on the cable to unplug it rather than pulling on the plug body. Sometimes the adapter jack gets worn out or the solder connection inside the laptop breaks. In these cases, usually no light comes on when you plug in the adapter or the AC power indicator light is intermittent.
Also, if you have a Sanyo battery pack there are some issues with the battery management firmware. Gateway has a BIOS update to address the problem.
Apr 15, 2011 | Gateway MC7801u Notebook
All of a sudden, my gateway laptop nv52 screen dims on AC and brightens on battery power. It must be a key combination because I suspect my cat walked across the keyboard.
Try this,press function(Fn) and the power up button/down button. that will fine tune the middle setting your laptop. the middle setting is one of 3 settings, you need to press function and f8 to switch between lowest, middle, and high. the middle setting can be any setting you like and will be the default setting when you use your computer with a chord or without it.
Thank You
Jan 04, 2011 | Gateway Computers & Internet
My Gateway NV52 was playing a movie then it went black. no external mouse connected. when I reboot this darn thing all i get is a black screen and none of the red lights will light up. I see that the power...
Since i dont have more details about the issue, i would recommend a complete system recovery.
Power on the laptop and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Also note that u will lose all your datas.
Jan 04, 2011 | Gateway NV5216U Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
Computers & Internet Logo
734 people viewed this question
David Payne
David Payne
