Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My remote controls for my garage door opener don't work. The wall switch does work. The batteries in the remotes are new. Any solutions?
    President:
  • 3,197 Answers
If you have the 3 button wall control check to see if the light in the wall control is blinking. If so press and hold the lock button for 3 seconds. If not, your logic board has most likely failed.
Posted on Sep 14, 2010
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
The remote opener in my far works, but the garage door opened on the wall of my garage will not open the door. What is wrong?
Perhaps the wall opener control needs to be accepted by the opener, press the button on the opener head unit and then press the wall switch. Consider new batteries before you do so.
Mar 04, 2011 | liftmaster Garage Door 1/2 Hp
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My 373LM Liftmaster remote does not work suddenly. Other remote, wall control switch and my car door opener works perfectly. I am sure it is isolated to just this particular remote. I doubt it is battery...
I would replace the battery anyway. Even with no use batteries drain over time. That's the easiest troubleshooting step and more than likely the problem. Once that's eliminated we can try harder solutions.
Sep 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Remote will not open garage door but the door still works
CHECK TO SEE IF THE LED ON THE WALL CONTROL IS FLASHING.
IF IT IS THE LOCK / VACATION SWITCH HAS BEEN ACTIVATED. THIS IS USSUALLY A SMALLER BUTTON ON THE WALL CONTROL OR A SMALL SWITCH ON THE WALL CONTROL.
WHEN THIS HAS BEEN SET TO UNLOCK THE UNIT, ALL OF YOUR REMOTE FUNTIONS SHOULD WORK.
Nov 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
129 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
