Question about Goodmans GPDR40 Digital Media Player
My goodmans GPDR40 X Pro shows the message UI resource data missing?
SOURCE: goodmans GPDR40
I formatted and reinstalled my PC, unfortunately I do not find my CD GPDR 40 PC Install Software, I would like to now are can I download it Thank!!!
Posted on Dec 29, 2007
  • 3 Answers
SOURCE: Goodmans GPDR40 problem
I had the same problem like everybody else since 2005 . GOODMANS GPDR40 X-Pro personal Media Centre. After Initialise the screen freezes - MASS STORAGE
DIRECT PRINT.
I have suspected that was the battery at fault or something to do with the power.
Why?.Because i have managed to let the Goodmans work, but only for a long time when
connected to the main adaptor.
I use it to record Video from sky,Or to use the unit as a storage drive.
Here are the steps to regain possession of the Unit.
First discharge the unit by leaving the screen on when in direct print mode,
(Move the cursor down to access this mode, normally it does this automatically.)
Make sure the screen display stays on in order to help the discharging of the battery.
Having the screen on will not switch the unit off until the battery is flat.
To have the screen on press the top button again if the display revert to a blank screen.
Once the unit is discarged the the unit will turn itself off.
Now we can connect the power lead to the unit and start the unit once more.
It normally last a couple of hours or more,but it will stop again eventually.
My suspicion is that the battery charger control is not working right and
after a period of time, may be a year ore less, will cause this problem
to all these units.
I hope it works for you too, even if not as before.
Ciao a tutti!
You can contact me at this email address:
messinasergio@yahoo.com
Posted on May 29, 2008
slaphappy
  • 24 Answers
SOURCE: GOODMANS GPDR40 MP4 PLAYER
Not to Sure ! Mine came with my player But on the Top it has... FAIRWAY Electronic co., LTD . hope this helps..
Posted on Aug 12, 2008
slaphappy
  • 24 Answers
SOURCE: goodmans gpdr40
Ive put The Install CD On a temp web site they are in a zip form so make sure you have some software to unzip them ... Like winZip.
http://playerzipfile.googlepages.com/
SOURCE: ui data
It means that the boot data has been corrupted. The only way to fix it is to reinstall the firmware, if you can find it. Now, Goodmans don't have the firmware (boot routines) on their site, nor do they have any other support for the GPDR40 (FYI, 'Logik' and 'Ventura' MP3 players also suffer from the same problems, with fixes hard to find) I have seen major problems with nearly all USB devices, in my opinion caused by cheap chipsets and shoddy hard/software in even the most expensive of devices. I believe this is known as 'built in redundancy' or 'built in failure'. If someone has a working unit, open it up, connect the HDD to another PC as a slave, then copy all files and directories (except the media) to another formatted HDD. in the cases of Logik and Ventura devices, the limited boot ROM will tend to reinstall the uncorrupted OS files automatically, resulting in a working player again. PLEASE, someone, copy some working files or find a firmware update. I have FOUR dead GPDR40's, and I'm an electronics engineer... Alternatively, check for support from the manufacturers before you buy anything. I would bet anything that these companies have NOTHING to do with the design or manufacture of these units, only the branding licenses, hence no support. Scumbags.
Hexenfinger.
Posted on Dec 19, 2008
Need installation disk for goodmans gpdr40
go to the mustek site & download the software for the h140 , it is the same software as I have both units , the only problem is neither vista or windows 7 will run the software
Apr 06, 2010 | Goodmans GPDR40 Digital Media Player
Data loading... pls help me
OK you need to restore data follow this steps:
use getdata back for Fat file system or get data back for ntfs
If you need help let me know
Regards
Ok use getdata back for Fat file system or get data back for ntfs
Regards
uttam109@hotmail.com
Jan 12, 2010 | Goodmans GPDR40 Digital Media Player
Goodmans Xpro GPDR40
I NEED DRIVERS FOR DPDR 40 X-PRO
Jan 05, 2009 | Goodmans GPDR40 Digital Media Player
No system boot files
seach for PVRDATA on your software disk and copy it to the device in windows - works fine
Nov 26, 2008 | Goodmans GPDR40 Digital Media Player
Goodaman gpdr40 play
I formatted my device using the PC when i got the message: "UI data miss, connect to PC". But i realized later that the entire system files necessary for the device to boot was also deleted. Now when the device is connected to the PC using the USB cable, it is not recognized. I dont know what to do next.p.o box gp13206 accra/ghana
Nov 03, 2008 | Goodmans GPDR40 Digital Media Player
Goodmans gpdr40
Apr 18, 2008 | Goodmans GPDR40 Digital Media Player
Ui data
Hexenfinger.
Apr 14, 2008 | Goodmans GPDR40 Digital Media Player
DIRECT PRINT.
to all these units.
Ciao a tutti!
Apr 10, 2008 | Goodmans GPDR40 Digital Media Player
Gpdr 40
Try going to www.mustek.com/product-resources/driv...
Nov 08, 2007 | Goodmans GPDR40 Digital Media Player
New software
14 August 2007 The unit will only play .ASF video files. I don't think you'll get anysoftware to run on it as it stands as it's only a playback machine not a handheld pc. Regards
May 28, 2007 | Goodmans GPDR40 Digital Media Player
Goodmans GPDR40 Digital Media Player Logo
51 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
