Question about GE GSS23SGSSS Stainless Steel Side by Side Refrigerator
About every 3 days the refrigerator and freezer stop working. The temperature goes up to 68 degrees and the outside pannel does not even put out water. I have cleaned the back and had a repairman look and says its not the sensor, so Is it the control board? after about 3 days it then functiones normal again making Ice, and door pannel works again producing water. I have changed the water filter also but I think that has nothing to do with it...
  • GE Master
  • 3,044 Answers
Hello mhreves,
Wrong number??
My favorite site (USA domestic)) is saying
you are missing a character in your MODEL number...
((I don't worry much about numbers... do IN FACT get changed over time... The important part is USA domestic))
Check out the part link below...
What you describe has to be a MAIN POWER circuit failure.
In the old days I would say "DEFROST TIMER"... without any hesitation... especially because of your "3 day" description.
New machines... your power control board typically takes that function...
I would strongly suggest you watch this included video...
then take pictures of your CONNECTIONS before you touch anything.
Always remove power & always wear an anti-static wrist strap when touching ANY CIRCUIT BOARD YOU CARE ABOUT.
$6 WRIST BAND (electro-static discharge = ESD)...
ROLL YOUR BOARD over and look at the bottom
for a BAD SOLDER JOINT under your (little black
... probably OMRON power relays...
(the quick touch of a SKILLED solderer's iron could ALTER
(or ruin) the functionality of that board...
((badly burned should be DE-SOLDERED & cleaned first))
(((better still send it in for professional refurbishment
YOU should order that SPARE BOARD you always wanted
(AFTER VERIFYING all your numbers FIRST).
LIKE at AMAZON (wrong number?)
Amazon com GE WR55X10956 Main Control Board Assembly for Refrigerator Home...
Different number
Amazon com GE WR55X10942 Refrigerator Main Control Board Home Improvement
Appliance parts (see VIDEO guide)
Hope this helps...
Carnac the Magnificent
Posted on Jun 26, 2017
SOURCE: Ice and Water not dispensing. Light button not working
I had GE come out and look at it. I wasn't home to ask questions. The repair man basically said it was a 'loose connection' in the back which is where the motherboard is for all the electronics. It took him less than 5 minutes to fix and he was gone.
Thankfully - it cost me zilch. I told a small white lie and said we were still under warranty and they didn't ask to verify. Can I get an Amen!
Posted on Oct 24, 2007
  • 213 Answers
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Posted on Nov 30, 2007
  • 2651 Answers
SOURCE: Kenmore side by side 596.57582790
you would have to remove the back lower panel of the freezer section to get a feel as to whats going on in there. behind the panel you will find an evaporator panel that should have consist ant frost pattern from top to bottom with no excessive clumps of ice.I'm assuming you don't otherwise your refrig would be working ok..
either theres only the top 1 or 2 coils actually have ice on them, and the rest of the coil is bright shiny aluminum. or there is an excessive amount of ice built up so far that you dont even see an evap coil.
if the first is true and threre little frost then that points to a sealed system/ low freon issue. and call a servicer. you should have a full 5 yr warr. for sucha problem
if its the second issue hen theres a defrost problem and youll need to replace either the defrost heater, defrost thermstat( most likely),or the defrost board/timer
Posted on Mar 25, 2008
  • 184 Answers
Posted on Apr 10, 2008
  • 1665 Answers
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
The freezeer works just fine, but the frige is only about 68 degrees. it is about 100 degrees outside here does affect operation.Frige and freezer have seperate temp adjust.
What is the temperature in the freezer? Anything below 32 degrees freezes water. Make sure condenser coil is clean and that air can flow over it freely. In the back behind a removable panel you will find the condenser. Clean it completely and make sure the fan operates when the compressor is running.. Also check for possible frost on the back wall of the freezer which would indicate a defrost problem. if there is frost there the problem is ether a bad timer, heater, or defrost thermostat.
Jun 11, 2008 | Frigidaire Refrigerators
The temperature in the freezer ~30 Degrees F
Condenser fan motor replaced. Refrigerator did not work either, so I got mistaken describing the problem.
Jun 09, 2008 | Whirlpool Refrigerators
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Jan 02, 2008 | Refrigerators
Open Questions:
GE GSS23SGSSS Stainless Steel Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
