Question about Codegen POWER SUPPLY CG|PS-350XA-12 RT (PS350XA12) Power Supply
Codegen 300 wt supply
My grandson needs 12 dc for a school project. how can I turn on this spare supply without plugging to a computer.
Thanks
Jim plgrims@gmail.com
You can do this doing shortcircuit between the green and a black wire in atx cable
Posted on May 23, 2008
Codegen 350xa
You wont find either on the web because working on power supplies is very dangerous. If you touch the wrong thing inside you will be severely electrocuted and probably die. I would strongly recommend just buying a new power supply and not try to save a couple of bucks.
Jul 30, 2012 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Noisy
The noise could be from dust that gets in cpu fan or power supply fan. Clean them but do not open the power supply. Better replace your power supply.
http://pcsupport.about.com/od/nonworkingcomponent/ht/fannoisetb.htm
Mar 14, 2012 | Codegen PS-400W-12 (PS400W12) 400-Watt...
My Codegen Switching Power Supply 350W Model 300Xi is smoking when I turn on my PC, a big cloud of white smoke when I turned it off.
There's obviously something wrong in the supply, but it's not worth trying to repair. Replacement cost of computer power supplies is so low that there's no reason not to just throw it away and install a new supply. The time spent in trying to troubleshoot the problem and cost of parts will certainly exceed the price of a new supply.
Nov 09, 2010 | AMD Codegen 350W ATX P4 Recommended...
Power Supply, Computer wont Turn on
Possible Power supply troubles.
1. Noisy Power supply Fan,,,,,
2. Burnt smell
You can buy cheap Power supplies that will last about a year & half for about $20. Or you can spend up to $100 + dollars.
Make sure you the power supply you pick has at least 300-350 watts or more.
Dec 19, 2009 | Codegen Computers & Internet
350w switching power suply
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Jun 26, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Codegen 450w model :200x
Run a jumper wire between your Green wire on your 20/24 port plug that would hook to the mainboard and one of the black wires in the same plug. I would put a pushbutton or switch in between the Green and a Black on that plug. You may need to put a load on the power supply like an old hard drive or a CDROM. Plug your power supply in and you will notice the fan turning. Use your multimeter to test for different voltages on the connectors. You should get +/- 12, 5, 3 Volts.
I just went into my basement and tested this out and it works great.
Enjoy
John
Jun 09, 2008 | Computers & Internet
Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Codegen POWER SUPPLY CG|PS-350XA-12 RT (PS350XA12) Power Supply Logo
406 people viewed this question
Top Codegen Computers & Internet Experts
Lyle Siemens
Lyle Siemens
shaun taylor
Gil Davis
Are you a Codegen Computer and Internet Expert? Answer questions, earn points and help others
