Question about Roper RES7646KQ Electric Dryer
Roper elec dryer starts and runs for 10 sec then stops runnning
  • 4,323 Answers
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 14, 2010
Dryer stops running
It sounds like the motor is going bad, but typically it won't start up right away after it shuts itself off.
Apr 03, 2014 | Amana NDE8805AY Electric Dryer
Ford F150 5.4, 2002 A|C clutch run for about 10 sec then stops
Try a jump wire across the low pressure switch on the receiver dryer,if
the clutch engages and stays on check for cold air.
if no cold air disconnect jump wire and regas.
Mar 02, 2013 | 2002 Ford F150 Regular Cab
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
Dryer run then get hot after about 10 min. it stops want start till about 2 hours later
try runing the dryer with out the vent hose.if it drys good than you have a problem with your vent line.
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer will not operate
This sounds like your motor is out. Also check out your start switch. Hope this helps.
Aug 14, 2009 | Dryers
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Roper RES7646KQ Electric Dryer Logo
268 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
