Question about Aiwa Audio Players & Recorders
Replacement CD unit Sanyo A1346229 for Aiwa Music Centre (Aiwa S1-540-028-000) I have an Aiwa Music Centre - now 18 years old but still excellent, except the CD player CD.DXM90M needs a replacement optical pick up: type Sanyo A1346229, Aiwa part S1-540-028-000. Repair shops can't seem to find a replacement (via Euras etc) but I love the system, so don't want to junk it. Can you locate/obtain a replacement unit? Many thanks John Thornely
  • FixItFun Sep 18, 2010
    Hi, many thanks for your response.
    The only information available on the part number is as I gave in the question, ie optical pick up: type Sanyo A1346229, Aiwa part S1-540-028-000. It is not KSS-xxx to my knowledge.
    I hope you can find how to source the relevant part.
    Thank you
    John
  • FixItFun Sep 26, 2010
    Thank you
  • 10,594 Answers
What is part description of Aiwa part number S1540028000
It is optical block unit, I need to know is its description as is it KSS-310 or KSS-210 etc
Part description would be written on little sticker pasted in part itself.
Thanks.
Posted on Sep 14, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 18, 2010
    OK, get back to you shortly with info, wait my next post please.
    Shahid Electronics Sep 19, 2010
    OK, I tried best to find out S1540028000 pick-up assy but it not available any where. Sorry.
    Shahid Electronics Sep 26, 2010
    I'm sorry, I tried best to locate that part.
The AIWA CX-ZR525 wont play cd's, it will only pick them up and leave them there with no music
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 14, 2014 | Audio Players & Recorders
Aiwa music centre
If you have power but no sound, check the speaker wiring on the back for shorts, if okay suspect the audio output chips. The unit will need to be dismantled for a closer look, check for open fuses, sometimes that will get it working.
Jun 07, 2012 | Aiwa Audio Players & Recorders
I have AIWA NSX-880 purchased in '99. During transportation it had got damaged. The CD part got damaged, the circuit got cracked. Recently gave it for repair, but I was told the CD tray cannot be repared....
This says Sony has taken it over, so Sony are unlikely to be interested.
AIWA Global Home
you might have more luck here
Aiwa Service Center in Hyderabad 040 24077328 Aiwa Repair Center in...
Or find someone like this
Aiwa CX NA555 Volume Repair
Basically you have an old and obsolete unit where no spares are available. This type of unit is deemed as a consumable unit, they break, you replace.
Nov 07, 2017 | Aiwa Audio Players & Recorders
AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Dec 18, 2009 | Cameras
Cannot hear cd, exchange keeps turning
Looks like the laser is not reading the CD. As long as the cd is not defective, the Laser has probably gotten too weak to read the CD. A replacement of the laser assembly would probably be too expensive a repair if the unit is more than 5-6 years old.
Aug 11, 2009 | Aiwa Audio Players & Recorders
Problem copying from cassettes or vinyl.
CHANGE RCA JACKS ,,COULD BE A BAD ONE,, ALSO ,,TRY BLOWING IT OUT
May 15, 2009 | Aiwa XC-RW700 2-Disc CD Recorder
AIWA XR-M98 Mini Hi-Fi system
The replacement parts are readily available, but without knowing what is broken, I'm not sure what to provide you. Can you describe the problem you are having?
Thanks,
Dan
Nov 03, 2008 | Audio Players & Recorders
Saving music on hard drive
After the MP3 songs are transferred from the PC to the Music Center via DMM, do not disconnect the power cord. The Center is updating its internal database to mark the changes of music library. Wait for around 20 minutes to let the Center update the database completely. When the internal updating is complete, you will be allowed to turn the Center into ECO Standby mode.
Apr 06, 2008 | Philips WACS700 Shelf System
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
73 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
