Question about Dryers
How do i take apart my GE dryer model number DBXR463EBOWW
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: I need to change a
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Posted on Jan 21, 2009
hektor1961
  • 70 Answers
SOURCE: How do you change belt on GE dryer model
You have to open the door right where the door closes if you look up you'll see two screws take those out and the top just comes off by lifting it up and then on the inside if your in the front of the dryer the screws are pointing to you so once you got the top look at the front panel but from the inside and at the top you'll see two screws one on left one on right take them out and grab the front panel and just lift it it sits on two little hooks or screws on the bottom i usually lift right and than left or left then right.
You will now have access to slide the new belt around the drum and ready to mount on the motor pulley and idler.
Pull your dryer from the wall and remove the back panel by the vent outlet.
You will see a diagram of how belt mounts over both pulleys, follow instructions and reinstall everything the way it was.
GOOD LUCK!
Posted on Aug 30, 2009
jsrock516
  • 5911 Answers
SOURCE: I need the part information for a new belt for
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Posted on Oct 28, 2009
Taking apart gas dryer GE VT850607c
Hello Molly McKellar,
VT850607c... ("model number" No good).
Try watching this instead...
http://www.repairclinic.com/PartDetail/Whirlpool-Dryer-Drum-Roller/WPW10314173/1925071?modelNumber=GEW9250PW0&ss=a8b5d651900&mr=1#repairHelpVideoTabs
Your model number did NOT resolve to any GE dryer in MY reality (cyber-wisdom)... However I remain confident of my life-long ability to take things APART...
Putting them back together again... Now there's the rub.
(if you takes pictures as you DIS-MANTLE... You'll be OK).
((Lots of pictures)).
Your basic dryers break down into 2 basic groups
(NO... Gas & Electric are amazingly similar)...
It is controls forward... (Like: GFDN160GJWW)
or controls on the back-edge (classic style)).
((against the wall, such as DBXR463PG4ww)
Since the BELT or DRUM ROLLERS about a deep as ONE can get... into (inside) the case... Go to one of the Parts "LINKS"
I will post below...
look up the "PART" & watch the VIDEO associated...
If you do start opening CONNECTORS (repeating again)...
Take pictures and look them over for USEABLE detail in
case yo get interrupted during your dismantle...
BEFORE YOU GET into trouble.
You will know EXACTLY where every wire & clip is supposed to go (back).
Good luck & happy hunting!!
http://www.appliancepartspros.com/parts-for-ge-dbxr463pg4ww.html
Whirlpool Dryer Drum Roller WPW10314173
Search Over 2 1 Million Appliance Parts
Aug 14, 2016 | GE Dryers
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
How do you change belt on GE dryer model DBXR463EBOWW?
GOOD LUCK!
Aug 30, 2009 | Dryers
HOW DO I REPLACE HWTING ELEMENT
depends on the model and type of dryer and if it's a "cake pan" re-string "or encased element there are too many variables w/o brand name and model numbers
Aug 04, 2009 | GE Dryers
I need a diagram of how to put back the dryer
See diagrams below, click on pictures to open:
Here you find all parts for dx4500.
If that was not your model , try entering model numbers below, they have the assembly diagram for almost all models:
Appliance Parts From PartSelect
Do not forget to rate the solution.
Thanks.
Feb 20, 2009 | GE Profile Harmony DPGT750EC Electric...
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
Jan 21, 2009 | LG DLE2512W Electric Dryer
HELP!!! Dryer will not work!!! MODEL#DBXR463EBOWW
check the door switch and the heater box main fuse,let me know-mike
Mar 22, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
214 people viewed this question
Top Dryers Experts
