Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
  • 377 Answers
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Posted on Sep 14, 2010
  • 1 more comment
  • pwillitz Sep 14, 2010
    Again, if you are new to the tool, this video under "See It In Action" will show how the locking tool works.
    http://www.themultimastersystem.com/inde...
  • Joe Anonomouse
    Joe Anonomouse Oct 19, 2013
    Ummm, the msx 636 II doesn't have the locking lever, silly! That's only on the newer 250Q!
  • BobInMA Mar 31, 2014
    What Joe said
My 250q surges speed control doesnt work
Fein 30762198013 but first before replace try to clean the variable resistor with a contact cleaner or wd40. and blow it out of dirt little chance sometimes it can help.
Mar 30, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where could i buy a new switch and capacitor for my multimaster Msxe 636 - 2thanks
A capacitor is in in practice not nessecary but sometimes its only inside for radio interference suppression. remove it the switch is if you not know it also made to disassemble because of all its a realy dirt sensitive, but rarely defect i have never replace this part in all the time this year 20 years switches of this model al very little screwdriver is neccesary open it a little not neccesary to dismount it completely and spray wd40 inside wait a moment and blow the dirt carefully out remount and control always the AC cable for shure after.
Jan 28, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the...
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Sep 30, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Jul 29, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Cracked lid/top of fein vac model 9-55-13
Contact Rudi at E & H Repair in Chicago. They are an Authorized Warranty Repair Center for Fein. The phone no. is 312-829-6770. Email is rudi@kooltools.com. Good luck
Jan 20, 2009 | Fein 9-55-13 Turbo II Bagged Canister...
RPM will start to slow and then almost quit
fein i believe is made in europe. i am guessing its the hz problem co`s the electronic to failed
Feb 22, 2008 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
286 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
