Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
I have a motorola blue tooth and I need to pair it to my htc evo.... How can I do that?
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR Sep 14, 2010
    What is the model of your bluetooth headset?
  • emanuelcapus Sep 14, 2010
    I honestly don't know what type it is....
    President:
  • 1,118 Answers
Ok, I'll give you a default procedure to put a blueetooth headset in pairing mode: starting with it turned off, press and hold the call button as if you were turning it on, but keep pressing the button until the indicator light is either steadily lit, or flashing rapidly, sometime in more than one color. This is usually achieved by holding the button down for some 6 to 10 seconds. Then, make your phone's blueetooth application search for new devices. After a while, your headset should appear on-screen. Make the application connect to it. If a pairing code (or passkey, or PIN), is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash some times, and enter the stand-by mode (normally flashing every couple of seconds). Your phone should also indicate that a headset is connected. However if the pairing process fails, after a couple of minutes your headset will quit the pairing mode, Turn it off, by pressing the button until the light goes off, and start the whole process again, firstly trying '0000' one more time, then changing it either by '1234' or '8888',
Hope you are able to sort your problems out soon, but, please, let me know if you further assistance.
Regards, Carlos
Posted on Sep 14, 2010
My phone can't find the headset. HTC EVO
Make sure you have your bluetooth device in pairing mode to do this you usually hold the power button down while turning on the blue tooth device,then there should be a light that stays on ,now that u are in pairing mode you need to enter a pairing code most bluetooth manufacturers use a 4 digit pin pairing code they are as follows 0000,1234,9999,or 1111, i hope this helps.
Mar 23, 2011 | Jabra BT4051 Bluetooth Headset
IHF1000 IS NOT PAIRING SUCCESSFULLY WITH MY VERIZON BLACKBERRY PHONE. I ENTER THE CODE 1-2-3-4 REQUESTED, NOTHING HAPPENS, SO THEN I REPEAT PAIRING STEPS?
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
Feb 25, 2011 | Motorola Radio Communications
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
I AM TRYING TO PAIR MY MOTOROLA HEADSET HS801 WITH MY NOKIA MOBILE PHONE BUT THE PHONE ISN'T FINDING THE HEADSET.
have you checked if the battery for the blue tooth is charged? And did you power the blue tooth device on, like wide that of the Nokia phone before you begin pairing?
If all the above are intact and the blue tooth is still not finding the phone, Then you have to test the blue tooth with another phone to be sure its not faulty.
Best regards.
Feb 19, 2010 | Motorola Mobility HS801 Consumer Headset
Need the code to pair my blue tooth motorola
Try using 0000 as it's the basic code for every bluetooth unless manually change. That is the factory default.
Dec 31, 2009 | Motorola Mobility HS850 Consumer Headset
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
479 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
