Question about Frigidaire FGB24L2A Gas Single Oven
The oven will not turn on. The stove burners work perfectly, but when we try to turn the oven on we just smell gas comming out
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Sep 14, 2010
I just turned on our pilotless oven and noticed the smell of gas. Turned it off naturally. The stove worked fine earlier in the day.
You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps.
Good Luck
Jul 31, 2014 | Maytag CWG3100A Gas Single Oven
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidaire FGB24L2A Gas Single Oven Logo
114 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
