Question about Dell Dimension 4500 PC Desktop
Trying to install dvdrom on my dell dimensin 4500
Any help with the install would be great. I am pulling my hair out...
  • 3,940 Answers
Let's see, here are a list of things to do.
1. If replacing an existing drive, open the chassis, remove old drive and transfer mounting rails to new drive. (Make sure the drive jumper is set to CABLE SELECT)
2. Mount new drive in chassis, connect the IDE and power cables.
3. Boot to the BIOS (F2 at boot) turn on caps lock, scroll lock and Numlock, the press CNTL+E, CNTL+F then CNTL+B to reboot, this will force IDE redetection and should ID the drive in BIOS
4. Boot to windows, see if the drive is now ID'd in device manager.
5. Install DVD playback and burning SW that came with the drive.
Posted on May 16, 2008
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
My dvd doesnot come out, it got stuck in the laptop. any no screen display, it is DELL Vostro 1510
- if you can't remove the DVD inside, there is a small hole besides the eject button if your not using a slot tray DVDrom
- you can stick a hair pin or a small pointed object to manually eject the dvd inside
- hope this work
- after this update your system for disk drivers
Jun 07, 2011 | Dell Vostro 1510 Laptop
How do I connect my dell 4500 to an ethernet connection? My desktop does not seem to have a connection port. My DSL company (AT&T) sent me a new modem motorola MSTATEA and it does not have a telepohne...
The Dell 4500 uses an add-on PCI card for ethernet.
You may not have ordered this PC with one.
You can purchase a card for this system, if you are comfortable with installing additional cards into the system. The system is
Here is the link from Dell on installing cards. http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1138309
Amazon sells these cards: http://www.amazon.com/s?ie=UTF8&x=0&ref_=nb_sb_noss&y=0&field-keywords=PCI%20network%20card&url=search-alias%3Daps
Jun 15, 2010 | Dell Dimension 4500 PC Desktop
Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Jun 05, 2009 | Dell PowerEdge 4600 Server
Unable to reconnect hard drive.
check  for the connection first try two r three combinations and still if u dont get it then the hard drive is fault
Mar 08, 2009 | Dell Dimension 4500 PC Desktop
Install memory
No. Your Dell Dimension uses PC-2100 type memory. Your Dell Dimension can support up to 1GB of memory. For optimal performance install the maximum amount of memory in each socket. Your Dell Dimension 4500 has 2 banks of 1 socket each for a total of 2 memory sockets.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Formatting my Dell Dimension 4500
sure..boot from an install or recovery cd..and format it from there
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
Switching from Dell monitor to LCD monitor
with out seeing the monitor i can just suggest pull out the cord which is in the old monitor and plug it into the new one, if it has the same audio plug slot, im not sure if the dell monitor has a special cord or not , so its hard for me to say sorry
Nov 21, 2007 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
59 people viewed this question
Alun Cox
