Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
My external hard drive is not showing up on any of the computers I put it on, what can be the problem???
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I know there is data on my phr-250a mcally external hard drive but it's showing empty folder
Leave it connected to your computer and try a restart.
If the folder is still showing as empty, power down the computer then disconnect the external drive.
Power on the computer and connect the external hard drive to a different usb port.
I had this exact problem with a 1000 Gb external drive that was full of movies and music. I thought it had all been lost .. After 2-3 days and repeated attempts of restarts and power-downs/different usb ports it suddenly was recognised again and has worked perfectly since
Jun 07, 2013 | Macally Phr-250a - Usb 2.0 2.5-inch Ide...
Hp hdd no show computer
Is this an external 1TB Hard Drive? Maybe it's to big for your computer. If it's an external drive try it on another computer and see if it works. There is also the possibility that the external 1TB drive is bad.
If it's not an external hard drive then try the steps below.
Click Start/My Computer and see if your hard drive is listed as a device. If not, turn the computer off, remove the battery, remove the cover that houses the hard drive on the bottom of the laptop then remove the hard drive from the bay. Wait 30 seconds and put the hard drive back into the bay and reboot. Now see if the hard drive is shown under My Computer. If not, the drive might be bad.
May 30, 2012 | Computers & Internet
I had problems with my Maxtor One Touch III Mini. It was a loose connection from the USB cable on the Drive's end, and when I tried to solder it, I damaged the connector. Is there an alternative to get an...
If you damaged the external case you have two options. Remove the drive from it and put it in a new external or put the drive directly into your computer.
Here is a guide that will show you how to open your case.
If the hard drive is a SATA DRIVE you can just plug it right into your computer with SATA cables. If your drive an IDE DRIVE you're going to have to find an adapter in order to plug it into your computer as the IDE connection on these smaller drives aren't the same size as the connections on normal sized drives.
The easiest solution would be for you to find out what kind of drive it is, and then buy a compatible external case to put it in.
Mar 03, 2010 | Maxtor OneTouch III Mini Edition 120GB...
How do I view the files in my LaCie backup folder? The show hidden files/folders option is checked and I still can't see anything.
It appears you have an external hard drive. It should connect to your computer with a USB cable. Make sure the external hard drive is turned on and running before you connect the usb cable to the computer. Some external hard drives have an on/off switch and some do not. you can hear it running if you put your ear close to the case.
When you plug it in, wait a few minutes and the computer should indicate that it has recognized it. (sometimes this does not happen) In any case, after a few minutes, open My Computer (Computer, in Windows 7) (sometimes referred to as Explorer- NOT to be confused with Windows Explorer which is an internet browser). You should see a list of recognized drives including your external hard drive. Doubler click on it and you should be able to see your files.
If it doesn't show in Explorer, the computer might be trying to assign a drive letter to it that is already taken. To fix that, go to Control panel, Administrator Tools, Computer management, Disk Management. You should see your external drive listed and you can assign an unused drive designation to it there. You should then be able to go back to Explorer and see it. You might have to refresh the Explorer screen.
Dec 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
External drive not showing up at all
i was working with (easy hard lock) and than i lock my external hard drive
now i cant get access to my external hard drive
(the program said dont lock external hard drive but i did i didnt know that )
can someone help me please
thanks
Jan 21, 2009 | Western Digital My Book Essential Edition...
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
Installation not happening
if you put it show Or auto run it ?
if test Any pendriver put ..what can show ..if it show &run it you try any other pc..other way you try add new hardware install...hope it ok.......
Jun 14, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
