Swingline stapler (model 51110) does not staple. Ok, this thing makes the stapling sound but does not staple. I have found that when I fill the tray with staples it does not close all the way. However even with just a third filled and a completely closed tray the stapler makes all the sounds, even puts an indent in the paper, but does not apply a staple. I've shaken out all the little loose batches of staples and even four or five pressed together single staples. There is now no noise of anything ratteling around when I shake this thing. I've removed the six screws from the bottom but am not able to pry the two pieces of moulding apart without what I think would be undue force. I'm wondering if there's a way to get the slider tray out all the way and see if anything is behind it.
5 Suggested Answers
SOURCE: stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
Posted on May 04, 2009
SOURCE: Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
Posted on May 08, 2009
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Posted on Oct 26, 2010
tech4allmen
  • 666 Answers
SOURCE: My SWingline Stapler will not
Is there a staple wire stuck in it?
Posted on Jun 24, 2011
Swingline model 67 broken staple driver part replacement
you buy a new stapler . they do not make that part as a replacement
Aug 27, 2016 | Swingline 06702 Model 67 Electric Stapler
My staples are stapling backwards.
Take your staples out of your stapler and reinsert new ones.
Try that and see if it makes any difference.
May 07, 2014 | Swingline 74729 747 Business Full Strip...
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
I would like to know where I can buy staples 804-809 for my Swingline Professional Saple Gun No. 10011
Hi,you can use any brand staples on your tool..
As an example here is a link on ebay for 5/16 staples..
Take care and please remember to rate me..Regards
Arrow 591188 300 Box 1/4"x5/16" Clear Insulated Stapleshttp://cgi.ebay.com/Arrow-591188-300-Box-1-4-x5-16-Clear-Insulated-Staples-/130360323235?pt=LH_DefaultDomain_0&hash=item1e5a14aca3
Nov 05, 2010 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
149 people viewed this question
k24674
jasbo
jasbo
