SOURCE: How to raise the handlebars on a 20" Huffy Rock It
Usually there is a hex bolt or some kind of bolt in the handlebar stem.
Loosen the bolt 4-5-6 turns.
Bolt will move upward.
Then hit bolt down with wrench.
Handlebars should be loose.
Raise handlebars to position.
Hold bolt upward with fingers while tightening.
SOURCE: raising the handlebars
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
SOURCE: Can I raise the handlebars? I
http://www.sheldonbrown.com/handsup.html Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
SOURCE: how do i raise handlebars on next 24 power climber bike
https://www.youtube.com/watch?v=lIYw7WG82WM
