Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
  • Anonymous Mar 13, 2014
    Dell Dimension 4400 wmic bios get serialnumber /value returns serialnumber= and that's it. Is there a way to set the correct value? Thanks!!
    Sergeant:
    Champion:
  • 256 Answers
DSTCD.iso: click here
just burn the ISO and make it bootable to use it.
Usage:
ASSET new_asset_tag Specify new asset tag
ASSET /d Delete asset tag
ASSET /o new_owner_tag Specify new owner tag (if applicable)
ASSET /o /d Delete owner tag (if applicable)
Posted on Sep 14, 2010
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
My computer system, #8wp2cl1-595b, is protected by a password authentication system
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
Jan 10, 2011 | Dell Inspiron Notebook
It says ys this computer is protected by Password Authentication system. can't access the bios or every thing give me master bios password for INSPIRON 6400 dell laptop with service tag CV5RW2J-595B
You can remove it with windows 7 password tools. For removing Windows login Passwords safely, I strongly recommend Windows Password Reset 9.0. Few days ago, I downloaded it at http://www.reset-windows-password.com I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes.
Aug 24, 2010 | Dell Inspiron 6400 Notebook
My dell inspiron 1545 is locked. i am the main administrator. how can i unlock it?
hi
http://www.kellys-korner-xp.com/win_xp_passwords.htm
or
http://www.lostpassword.com/windows.htm
find your solution from above links
Aug 01, 2010 | Dell Inspiron 1545 Notebook
DELL XPS M140 MXC051 LAPTOP BIOS PASSWORD
Most laptop or notebook computers feature enhanced BIOS security, and BIOS passwords on laptops are hard to bypass. Several companies offer laptop security chip services that can be used to bypass the BIOS password on Dell laptops or notebooks and reset the security. They can provide a master password from the Dell Service Tag of your Dell laptop. This master password will allow you to bypass the existing password and enter the BIOS and reset the unknown password. To generate the master password they need to know the Dell Service Tag of your unit. Dell Master Password Recovery does not require soldering or disassembly of the laptop and supports most Dell models.
Dell BIOS passwords can also be reset by replacing the laptop security chip. Passwords can also be recovered from security chips that have been removed from laptop or notebook systems. These passwords may be required to attempt to unlock protected hard disks. Passwords recovered from these chips are the original BIOS passwords and may be the same as the hard disk password, but are not guaranteed to be the same and may not unlock the hard disk.These are usually damaged in the process of recovering the passwords and are not suitable for replacement into a computer.
Apr 08, 2010 | Dell Inspiron XPS M140 Notebook
How to reset bios password on dell latitude e6400
The above answer is not totally correct. Any solution regarding removal of battery, shorting pins together, etc does not work. However, what does work is to use the Dell Asset/Service Tag BIOS Reset Tool. Find an Bootable CD ISO of the tool (can be found on torrent sites or email me and I can send), boot the CD image and when you are asked if you want to delete/change the service tag select "Y". When asked for the new service tag number re-enter your current service tag. Then the tools erases the BIOS and inputs the new service tag. A by-product of this process is that the BIOS master password is removed from the BIOS.I knowthis works because I just did it less than one week ago.
Nov 28, 2009 | Televison & Video
How can i bypass my password on my dell
You cannot bypass the password security feature on a Dell, you have to contact their support team and give them the service tag off the bottom of the case.
Viewing Existing Asset Tag and Service Tag
  1. Boot the computer using a bootable floppy disk or CD.
  2. Type cd c:\Dell\Util and press <Enter>.
  3. Type asset and press <Enter>.
The only thing I can suggest if you want to try it.....remove the RTC (CMOS) battery for approx. 30 minutes. Re-attach the RTC battery, take out the main laptop battery and set it aside. Now, power up the laptop using just the AC adapter. Boot the laptop upand see if the password is cleared out. The laptop may still ask you for a password, just hit enter and see if that clears it off. If it does, get into the bios by striking F2 when you see the Dell splash screen and reset the time and date. power off the computer and reattach the main battery. reboot
The other option is to "short" the two contacts of the RTC battery until the laptop does its initial post. This can be done two ways, if your RTC battery is attached to the motherboard by a small cable, remove the battery and look at the socket the plug fit into. take a small wire and "bridge" the two contacts in the plug, this will "short" the connection and cause an immediate reset during POST. If your battery sits ina flat socket by itself, then remove the battery and short the two metal battery contacts inside the battery socket. Power the laptop up with this "short" in place until the laptop POSTS or for approx. 2 minutes until you are sure that POST has happened...just iin case you have your laptop torn apart and can't see a screen. Once this has happened, remove the "short" and put the system back together...again, it may still put the password test box up, just hit enter and see if it bypasses it.
You RTC battery is in a small compartment inside the main battery compartment, remoce the main battery and you will see a small access door on the side wall, the battery is in there.
Nov 03, 2009 | Dell Latitude D600 Notebook
FORGOT BIOS PASSWORD DELL LATITUDE E6400 HELP ME PLEASE...!!! THX
The above solution does not work on an E6400. Any fix regarding removal of battery, shorting pins together, etc does not work. However, what does work is to use the Dell Asset/Service Tag BIOS Reset Tool that is available on Torrent Sites. Boot the CD image and when you are asked if you want to delete/change the service tag select "Y". When asked for the new service tag number re-enter your current service tag. Then the tools erases the BIOS and inputs the new service tag. A by-product of this process is that the BIOS master password is removed from the BIOS.
Jul 29, 2009 | Computers & Internet
I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 28, 2009 | Dell Inspiron B130 Notebook
Problem with dell d510 bios password
Go here http://www.download.centre4service.com/software1.html
and downloaded the DSTCD.ISO (you will need a program to burn ISO image) and install it to CD.
Or There is a bootable USB option.
and floppy disk option. Just choose the best one for your situation
Insert CD,USB drive,Or floppy disk, Restart computer,
Enter Boot Menu(should be F12).
It will Asks if you want to modify or erase Service Tag. Answer Yes.
It will ask other system questions, answer yes to all.
Restart and look in the BIOS to make sure password has been removed.
May 06, 2009 | Dell Latitude D510 Notebook
Computers & Internet Logo
705 people viewed this question
David Payne
David Payne
