Question about Cell Phones
Bt studio 4100. I have no ring tone not receiving calls and can't make calls no problem with line?
SOURCE: Nokia 6020 not ringing
Change your Cellphone!
Posted on Jul 26, 2007
  • 67 Answers
SOURCE: No ringtone
what you have to do is to go your nearest service provider ask him to replace the ringer speaker for you or you check the settings of ringing style.advise by dogy
Posted on Dec 21, 2007
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
vrabhilash
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
No dialling tone and cant receive or make calls base is ok and will ring phone to search for it
The base is not connected correctly to your phone line or there is a problem with your phone line. Check with your provider.
Nov 04, 2014 | BT Freestyle 710 Cordless Phone - DECT 1 x...
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Brother intellifax 775
Did you get DSL service? You don't need anything except an ANALOG phone line.
Oct 19, 2008 | Brother IntelliFAX 4100 Laser Fax
We have an se445 cordless phone/answerphone. with answerphone on, the line rings 4 times then stops briefly before continuing to ring instead of cutting onto answerphone. BT line has been checked and gain...
Regarding the Philips SE445 cordless phone/answerphone. I posted my problem where it rings 4 times then continues to ring without cutting into the answerphone. My phone is now fixed and working as it should which is great. I was unable to make calls because I had no dial tone and although Virgin checked my line and said it was fine, it obviously wasn't. The problem was with the line in the Exchange Box - the big green boxes that are located on the roadside - the line was broken there. Once fixed, I had my dial tone and the SE445 is working perfectly. To nomad1066, I would insist that BT check their Exchange Boxes as this is probably where the problem lies. Check whether you have a dial tone. Hope this helps.
Jul 24, 2008 | Lands Phones
Both phones are flashing base 1 with no ring tone on a bt studio 1500
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Jul 14, 2008 | Lands Phones
BT Freestyle 2200
I think the internal ringer is a default and cannot be changed, but the external ringer can be changed.e03e2a2.jpg
Jun 26, 2008 | British Telecom Freestyle 2200 Trio...
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Cell Phones Logo
312 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
