Question about Carrier Heating & Cooling
I have a 1996 carrier 50hs-30. the condenser fan will run for 30 min give or take then go off on OL. wiring is correct, correct cap size (7.5 uf) is correct. Im leaning towards a voltage problem... getting 205 vac at my disconnect. A/C is powered by a 3 phase 240 panel. Also with this particular model what direction should the fan blade go?
    President:
  • 1,515 Answers
Hi, if the motor is getting hot enough to shut down on its internal OL, you are loosing the motor. Even though you have a 3 phase panel, this motor will only be a single phase motor. Sounds as though the run capacitor is doing fine if you have no oil leaks, or swollen areas on it, so if you had a clamp around amp probe you could check the R.L.A and compare them to the motors data plate or sticker on the motor housing, or condenser it self. This would tell you that the motor is over amping. If this motor has oilers on it you can get a zoom spout oiler at a hardware store and give them a shot of oil. Some are sealed and you can't do this. Also, wash the condenser coil real good to keep the head pressure down, this will help. If it continues, you will need to get a replacement motor. There is a arrow on the motor showing the direction it turns, so when it runs, it is either cw or ccw. You can tell by the pitch of the prop, as it pulls air through the coil and out the top, so the blade/prop needs to scoop the air up, so look at the shape. The best way since it is single phase, is when it does run that's the direction it goes.The unit is 14 years old and thats alot of hours on that motor. I replace this motor in the summer more than any other part. Remove the fan guard and let it run. Carefully touch the motor to see how hot it is when it stops. I bet you can fry an egg on it. You will need a motor, but try cleaning the coil, and if it has oilers, oil them. This may keep it going through the summer. More then likely, the motors had it. Please don't forget to rate me and I wish I could give you better news, but its common to loose this motor as its in the heat all the time, and its hot when it runs. Please keep me posted. If this motor has ever been replaced before, they could have put a reversible motor back in. Just look at the prop when it turns and you can tell as it will scoop up the air by the pitch of the blades. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 14, 2010
Need cap size for Armstrong A/C unit # SBU10B30A
The value of that cap is stamped on the metal case of the cap. The number just before the letters uF is the number you're looking for.
May 09, 2017 | Heating & Cooling
I have a 55/15 uf dual cap that I want to replace with two single caps. One 55 uf and one 15 uf. How do I wire the caps?
You'll need a jumper to connect the common leads to 1 side of both caps. Then put the 55 µf and 15 µf leads on the respective caps. A/C caps have no polarity.
May 12, 2016 | Heating & Cooling
How do I install the Start Capacitor and Run Capacitor
the 30 uf side is for compressor run cap and 5 uf side is for fan motor. the other capacitor is for compressor start should be able to replace wire for wire.
Sep 23, 2015 | Heating & Cooling
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
I just purchased an fse1028sf to replace my faulty fan motor. I purchased it from a a/c supply store. My existing fan only had three wires. They were brown, black and purple. Black to: capacitor "c"....
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
Shastalaker7
May 03, 2010 | Heating & Cooling
YORK CONDENSING UNIT MODEL H1RA042506D WIRING SCUMATIC BLOWER MOTOR WILL NOT START WITH OUT A PUSH. START COMPASITOR MAY BE BAD BUT WITCH ONE IS IT. MOTOR NAME PLATE CALLS FOR A 370MFD. I FOUND A 36MFD...
The capacitor for the fan will read 370uf 5 uf. The 370 is voltage at cap. My guess would be a 7.5 uf cap for your fan. If you read the cap. it will tell you size. Fan caps go between 5 and 20 uf or microfards. Easy to replace you can do it yourself. Rus
Oct 29, 2009 | Heating & Cooling
I have a victory the defrost timer was replaced and noticed start cap. was bad, replaced but turn on and nothing runs? evap.and condenser fans dont run.nothing?
You might check the defrost timer. They come set on defrost. You can usually use a screwdriver to turn the timer manually to get it to immediately start. I did not check the schematics for yours but you may also check that the cap. is of the correct uf rating and that the wires are in their correct position.
Aug 04, 2009 | Victory Freezer Freezer Roll Thru two...
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
