Question about Cycling
Wont stay in high gear - Cycling
  • 186 Answers
ADJUST THE REAR DELAILIER.THERE ARE 2 SMALL SCREWS.TRY UNDOING THEM.THIS WILL GIVE THE DERAILIER MORE SPACE TO MOVE OVER.IT IS PROBABLY OUT OF ALIGNMENT
Posted on Sep 14, 2010
Wont shift from nutral in to gear while running
Often, it mean that the clutch stay engage.
Now the question can be, is the idle to high for the clutch to disengage while at idle? you might try to reduce the idle speed by turning eather the nob on carburator or the ajustement on the cable.
then if the idle is very low and the clutch still engage (that is why you can not shift) you migh want to check at the clutch and see if it is not stuck.
Nov 07, 2013 | RTO 125cc Full Size Adult Quad ATV
1997 gmc 1500 went to start and tach and speed odometer not working and transmission shifts in hard and wont shift down stays in like high gear
Check transmission fuse its the one labeled PRNDL or similar.Use a test light when you check it by the way.If the fuse is good then its probaly your ignition switch failed.If that fuse is bad or the ignition switch is not suppling power to that fuse your tack,speedo,and gear indicator wont work, and your transmission will go into a safe mode.Safe mode is just the transmission staying in 3rd gear all the time until you fix this.
Aug 26, 2011 | 1997 Chevrolet K1500
Car want drive uphill
It sounds like you have a Auto Gearbox problem and the trouble could be the forward pump is sticking alowing the pump to stay in high and not dropping down 1 or2 gears ..So take to Auto shop and get the pressure tested on forward band and pump assy.
Let me know how you get on ... Ron
Oct 20, 2009 | 1996 Volvo 850
Put it in drive and stays in high gear wont shift
Bad connection where the wires from the tranny plug up or you have a bad transmission control module, located I think underneath the dash next to the ECU module, looks like it except smaller.
Oct 08, 2009 | 1997 Geo Metro
Wont shift into drive
Have you changed the fluid & filter lately? Start there, much cheaper fix than anything else.
Sep 28, 2009 | 2003 Chevrolet Tahoe
Car wont upshift out of 2nd gear, sometimes when
it sounds like you have a faulty ignition switch
Sep 11, 2009 | 1999 Chrysler 300M
Polaris wont stay in high
ajusted the linkage for the high gear
Aug 14, 2009 | Polaris ATV
ATV Polaris 330 (I think trailblazer) wont shift into gears
I have one of these and it always throws my friends for a loop. You have to push the foot brake to get the bike in park or high. It should shift very easy with the brake down, if not check if the spring didn't come off of your brake pedal. I hope this helped.
Apr 04, 2009 | Polaris ATV
Cycling Logo
26 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
