Question about Sears Garden
Craftsman power propeled mower 917.376735 cable broke, bought new one [917 407816] How does it hook to gear case ?there is another spring hooked to the only other hole on gear case! Please advise? Thank you Richard
3 Suggested Answers
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Where does the spring on the craftsman 1000 hook
If you are talking about the spring that allows you to dissengage the deck blades, the back end attaches to the hook or hole on the lever and the front attaches to a hook or hole on the front of the top of the deck.
Oct 04, 2014 | Craftsman Garden
The clutch return spring broke on my lawn tractor model 917.272242 and i cannot see at what points it connects my diagram is not a real .can you help
If you go to searsparts.com and put in your model number they will have a diagram as to how the spring attaches.
Jun 20, 2014 | Craftsman Lawn Mower
How do you assemble the two springs on a sprint 375 briggs and stratton ?
The ends of both springs hook at the loop of the metal linkage connecting the governor vane and throttle shaft. The other end of the small spring hooks onto a small upright plate approximately 1 inch towards to the front of hooked end of the spring. The longer spring hooks onto a large hole in the throttle plate.
A problem that does occur is the plate becomes bent when the mower us pushed under shrubs. This drops the speed of the mower to a low idle. If this is the case then with a pair of pliers, gently twist that metal plate to obtain a RPM setting of 3,100. Don't be tempted to increase the revs to much or the conrod will break and punch a hole through the engine block.
May 07, 2014 | Craftsman Garden
Drive wheels will not engage
I take it htis is a self propelled?
cable broke or out of adjustment
gears on wheels stripped
belt off or broke
Oct 23, 2013 | Craftsman Garden
Troy bilt self propelled mower stopped working
one side to the arm for the pulley and the other to the body look for a small hole to fit it threw
Aug 13, 2012 | Garden
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
Apr 29, 2009 | Garden
Garden Logo
94 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
