Question about Kenmore 29042
Kenmore model# 417.29042991 front load washer won't drain. I can hear some clicks and electrical humming like its trying to do something, but then just continues to agitate until the en of the cycle. Won't go into spin cycle ,I presume because the washer is still full of water.
Lumpy816
  • 246 Answers
SOURCE: kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 132 Answers
SOURCE: top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 107 Answers
SOURCE: Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Posted on Apr 22, 2009
  • 4088 Answers
SOURCE: replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Posted on Aug 18, 2009
Testimonial: "thanks, i added more comments to my question."
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
I have a model 417 Kenmore front load washer which stopped running and shows a E 20 error message in the window. What does that mean and how can I get it operating again?
E20 error code means that the control does not see it draining water out.
When you start the washer, you should hear the drain pump running or at least making a humming noise.
A service technician would:
- Check the drain hose for restrictions
- Start the washer and listen for the drain pump operating.
- If the drain pump is not operating, a technician would then check the voltage supply to the drain motor.
The technician would remove the lower access panel by removing the screws located along the bottom of the panel to access the drain pump assembly.
If you take off your lower front access panel click this link and check item number "18": Parts_Diagram
You will see the pump inside the bottom of it, with the 2 black rubber hoses attached to it. Here is the pump sample: drain-pump-assembly Try to look this part with the correct model number of your device.
Hope this helps.
Aug 16, 2011 | Kenmore Washing Machines
My Kenmore 3.5 super capacity front loading washer won't start. I can hear the click when I close the door, so I know it's not the latch. The lights on the right side are all lit up (above the...
the model # would be very helpful in diagnosing the problem it usually is on a label on the rim inside the door and sometimes their is a second label on the back of it
Aug 04, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
Kenmore Washer will not drain
Hi, When the the water is suppose to be draingin, do you hear the motor humming at all?
It could be that something is plugging the pump. You can tip the washer toward the wall and look underneath. The pump is right behind the front panel and easy to get to. You can try lowering the drain hose into a bucket and see if the water will release.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 09, 2009 | Washing Machines
Mar 03, 2009 | Kenmore 43142 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
93 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
