Televison & Video Logo
Posted on Sep 14, 2010
My Samsung T.V screen is constantly shaking at very low rate.I have recently bought Airtel DTH & i assume that after that my T.V started this problem.I am not sure about it,because when i detached DTH from T.V,screen still shakes.I don't know that whether should i call to Airtel DTH, or Samsung Co.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
837
Points
I have that problem with my Samsung TV!!! I unplugged every input and just used the TV through Internet TV and the screen still shakes. I have had the digital board replaced and that just made it worse
How 2 signal unlock in airtel dth
you have to recharge your set up box to unlock or go to service center to unlock
Jun 09, 2017 • Cell Phones
Check engine light blinking car shaking, oil light on after a few miles from starting
May be low oil, low oil pressure (faulty oil pump) or a bad pressure switch. When your at highway speeds the pump, pumps faster & brings the oil to the right PSI. Try a thicker oil than called for, get the oil pressure checked,oil leaks? & get the switch ckd out.
How can i connect the airtel dth to umax tvision 5821
use av cable yellow,red and white pin cable with tvishion
My vizio has a wierd black box in the bottom right corner that has my dish network on it while i am playing video games how do i turn it off.
i dont have a solution 4 ur problem, but this might be a probable reason 4 ur problem
this will happen in old lcd televisions and this is one of the disadvantages in having an lcd tv.
if a constant patch of colored icons like the channel logos (in your case it should be your dth operator logo) that part of the screen in the LCD screen will get decoloured and this will start to showup in plain screens as a patch (eg when you connect playstations etc).
else try to switch off your dth while connecting other devices to your lcd
How to connect two different televisions(Also operate) with one airtel dth set top box
If you split the signal two ways out of your box, it will feed both sets with the same programme.
I PURCHAGE A COUPON DTH AIRTEL RS 500 BUT THAT SHOW INVALIDE PURCHAGE DATE 29.11.10
if it shows an invalid date bring it back to them tell them they have the wrong date on it so they can correct it
1helpful
I AM FROM INDIA I RECENTLY PURCHASED AN AIRTEL DTH HD VERSION, SINCE I HAVE A SAMSUNG LCD MONITOR (SYNCMASTER 2233sw) WHICH SUPPORTS FULL HD (1920X1080). MY MONITOR RUNS FULL HD WITH DVI CABLES OF...
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more http://www.hdtvsupply.com/hdtodvico.html , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
6helpful
2answers
Need code to make universal remote work on sony tv
hello sir,
i m having problem please n please solve it........
i hv recently buyed a new LCD Sony Bravia KLV32BX300 ON 2nd FEB. 2011 and im having Airtel digital tv HD alos and i have connected LCD and DTH with HDMI cable ok....then problem is that how to make my DTH universal remort to operate my tv remort sensor..how to sync..my sony remor with dth remort..and i have try my best but im faild i know my dth remort code that is [OK+2] HOLD THESE buttons atleast 3 sec. ...............tell me what was my sony bravia pairing code.........please please nnnn please
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
