Something happened to where my tv wont show the show, but when i click on the menu box , the menu box shows up fine. i thought it was the picture tube but my brother n law came over and messed with the menu box and changed something and it showed up just fine. Now it happened again dont know how it keeps happening. please help. it is a 55inch flat screen.
  • 2 more comments
  • showtyk Sep 17, 2010
    i have tried to post my model number for 2days and it won't go through on here. any solutions?
  • showtyk Sep 18, 2010
    model # is P52830BL
    and the brand is RCA
  • showtyk Sep 30, 2010
    The tv started working all of a sudden. I was cleaning and looked up and it came on! Thanks a bunch. Still not sure of what happened, but oh well!
  • 10,594 Answers
I need model number and brand info of your tv to diagnose possible cause of problem.
Thanks.
Posted on Sep 14, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Sep 17, 2010
    You can try again to post model number as I.m getting your comments now
    Model number and brand info would be written on sticker pasted at rear of tv
    Shahid Electronics Sep 18, 2010
    Hi
    Change video source in tv, find source/ input button on remote to change video source / video input of tv to get video signal of connected cable box.
    Ok, I will try this as soon as I get home. Hope it works, but what makes it keep happening?
    Shahid Electronics Sep 19, 2010
    I guess input/ source got changed by pressing button by mistake
    Shahid Electronics Sep 30, 2010
    Wow great, seems tv needs to be reset or any connector maybe lose plugged.
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
The tv worked fine. The tv is on but it is not showing any picture it wont even show me the menu. what do i do?
Try reconnecting the wire from the cable box, or satallite, to the tv, if not try giving it a good wack
May 06, 2012 | Hitachi 50VG825 TV
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
My x box wont show picture but I can hear it
it is just probebly the chored, i had my xbox on my computer and the same thing happened i moved it to a tv and the picture showed up
Dec 12, 2009 | Microsoft Xbox 360 Console
Turned on my Mitsubishi WD-52525 this morning and none of the on-screen displays are working. Picture is fine but volume control doesn't show on screen- it does adjust though, can't access menu or at least...
I usually do not give a one line answer but here is what I would try if I were you:
With the set on and using the original Mitsubishi remote:
MENU, 1, 2, 3 ENTER.
This is the soft reset for the set--it will or should shut off and come back on--you may have to autoprogram it etc.
There is also a HARD reset that returns the set to the condition it was when new in the box.
Try the soft reset and see what happens.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Showing picture in three segments
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Jan 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
No pic or sound
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 22, 2007 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
