Question about Olympia Mastertype 3 Typewriter
How do I clear the margin setting - Olympia Mastertype 3 Typewriter
  • Olympia Master
  • 3,594 Answers
Go to the margin, press don't hold the mar rel key, space or backspace to the location desired, press L. or R. margin depending on which on you are setting.
DickyO
Posted on Sep 14, 2010
Testimonial: "Thank you for your assistance. It worked."
How to clear history of tabs and margins to start over on the Brother GX-6750
Unfortunately, I don't think you can reset all of the margins and tabs at once. To reset a specific margin, move to that margin and then press ALT and the 6 key simultaneously. (That's the Margin Release.) If you are resetting the left margin, press the backspace (or space) key until you reach the new margin location. Then press Alt + 7 (L Margin) to set the new margin. For the right margin, press space (or backspace) until you reach the new margin location. Now, press Alt + 8 to set the new right margin location.
You can clear all of the tabs by pressing and holding Alt + 0 (tab clear) for over half a second.
The manual for the GX-6750 is available from Brother on the product support site: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=GX6750 . Click on the Manuals & Documents tab. The direct link to the manual (in English) is http://www.brother-usa.com/VirData/Content/en-US%5CTypewriters%5CConsumer%5CUsersManual%5CUM_AX325_GX_6750_EN_5674.PDF / The procedure to set the margins is on page 2. The procedure to set the tabs is on page 5.
I hope this helps.
Apr 26, 2016 | Brother Office Equipment & Supplies
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
How do I clear the right margin?
Usually, with most of these machines, you move the print unit to the margin and then press Margin Release. This will allow you to move the print unit along to where you want to set the margin.Then you press the Set Margin key.
Apr 20, 2010 | Brother EM-530 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
Sep 02, 2009 | Office Equipment & Supplies
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Cannot clear left margin
hit the "mar rel" button at the top left of the keyboard, using only the backspace and/or spacebar position the printhead where you want the margin set, then hit "l mar" the margin should be set there now. this works for the right margin also
Jan 05, 2009 | Swintec 7040 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
Olympia Mastertype 3 Typewriter Logo
297 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
