Question about Sun MySQL
My SQL Server changed IP (from ISP) and now even when I changed the IP on a new session connection, I get the error 1045 with the username@old-IPnumber not the new IP. Example: Host IP: 172.x.x.x (new IP) the error 1045 access denied for user@132.x.x.x (old IP)
You could refer to user@localhost in your connectionstring
this should resolve your problem when the database is on the same machine
Posted on Oct 25, 2011
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it.
1. Open SQL Server Configuration Management and stop SQL Server Services.
2. Install SQL Password Genius full version and run it on computer.
3. Click "Open File" button to import master.mdf database file into this recovery tool.
4. Select user in list and click "Reset" button.
Instantly, new user password would be available for SQL Server logon after you type new password for user.
Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
Jul 04, 2014 | Microsoft SQL Server 2008 Enterprise Full...
Tip
4 Methods to Change MS SQL Server Password
Have you ever forgot or lost your MS SQL Server password? Did you reinstall MS SQL Server or change SQL Server Password by some ways at that time? I once forgot my MS SQL Server password and I reinstalled My MS SQL at last as I failed to find some good methods to solve the problem. What annoying and terrible experience it is! In order to avoid reinstalling SQL Server for a second time due to the same reason, so I collect some methods to change SQL Server password for sa account.
Method 1: Use Command Prompt to Change SQL Server Password
Step 1. Open a command prompt (Start -> Run -> cmd)
Step 2. Type the follow commands, and press Enter after each line:
Osql –S yourservername –E
1> EXEC sp_password NULL, ’yourpassword’, ’sa’
2> GO
The yourservername is the name of your server, yourpassword is the new sql sa password.
The command line 1> also can be changed to other command, the model is EXEC sp_password ‘oldpassword’, ‘newpassword’, ‘sqlaccount’.
Method 2: Use the Query Windows in Management Studio to Change MS SQL Server Password
Step 1. Open SQL Server Management Studio
Step 2. Open a new query
Step 3. Type the follow commands and excute:
GO
ALTER LOGIN [sa] WITH DEFAULT_DATABASE=[master]
GO
USE [master]
GO
ALTER LOGIN [sa] WITH PASSWORD=N'NewPassword' MUST_CHANGE
GO
The NewPassword is set for your SQL Server sa account.
Method 3: Change SQLServer Password by Windows Authentication
If Builtin/Administrator is present in SQL Server, you can login with an ID which is member of Administrators group and change sa password in SQL Server. Just do as follows:
1. Login into SQL server using Windows Authentication.
2. In Object Explorer, open Security folder, open Logins folder. Right Click on sa account and go to Properties.
3. Type a new SQL sa password, and confirm it. Click OK to finish.
After restarting SQL Server and all its servers, you can log into SQL Server by sa login with new SQL sa password.
Method 4: Change MS SQL Server Password with Third Party Software
In addition to the methods above, you can aslo choose some SQL Server password recovery tool to change SQL Server password. MS SQL Server Password Unlocker is one of the good MS SQL passwrod reset tools which can help you change SQL Server password in a few seconds. It allows you to chage MS SQL password on SQL Server and Express 2000/2005/2008.
Following is a guide for you to change MS SQL password with MS SQL Server Password Unlocker.
Step 1.Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with it.
Well, the four solutions are the easy-to-use MS SQL Server Password Reset ways.
on Aug 10, 2010 | Computers & Internet
Does the Asus RX3041 work on a PPPoA network
Off course it will work but you the software from your ISP. It is resposible for connecting to your ISP which then assigns a dynamic IP for you for each session and the IP is whichever happens to be availble at the ISP's server end.................sodeep
May 26, 2009 | Computers & Internet
Can't connect
It will be one of two things or both - either your computer is notsetup for DHCP or your router is using the same IP address as your ISPor both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
Toconfigure your computer to use a DHCP IP address, go to the Controlpanel => network connections => Properties (right click on yourdefault connection) => double click Internet protocol (From generaltab) => (a new window pops up) from the general tab ensure that"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 10, 2008 | Buffalo Technology WHR-G54S Wireless...
Java.sql.SQLException: Network error IOException: Connection refused: connect
I too was facing the same problem as mentioned by you and couldn't connect through telnet localhost 1433.
Solution : Just go to SQL server configuration manager----SQL Server Network configuration----Protocols for SQLEXPRESS and in that right click on TCP/IP and in properties field make all TCP/IP port to 1433 which is blank. Start and Restart the SQL server and you can telnet localhost 1433 and it works. Hope this will help.
Ghanshyam
gimatpune@hotmail.com
Aug 07, 2008 | Microsoft SQL Server 2000 Standard Edition...
SQL 401: cannot open database
SQL database Recovery Software remove errors from SQL server database and allow recover your all database of SQL Server 2012 or below versions. The software support with all over version of SQL server. Try at here:-
SQL Database Recovery
Jun 06, 2008 | Computers & Internet
Connecting of SQL Server and .net
TITLE: Connect to Server
Cannot connect to KRISHNA-02E4A78\SQLEXPRESS.
ADDITIONAL INFORMATION:
Login failed for user 'KRISHNA-02E4A78\Guest'. (Microsoft SQL Server, Error: 18456)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&EvtSrc=MSSQLServer&EvtID=18456&LinkId=20476
BUTTONS:
OK
Jan 10, 2008 | Microsoft SQL Server Standard Edition for...
Sun MySQL Logo
119 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
