Question about Kenmore Dryers
Cloths are not drying and it smells like gas in dryer (gas dryer and no gas leaks)
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
  • 18 Answers
SOURCE: gas smell from dryer
your igniter needs to be replaced.
Posted on Feb 04, 2007
dididsaythat
  • 291 Answers
SOURCE: dryer Tronm DLE 2514
If its new u should have a warranty still on it.. most have a Leat a year... Gas isnt anything to be messing around with.. Find out about u warranty or call a repair man.
Posted on Sep 08, 2007
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
  • 158 Answers
SOURCE: gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Posted on Aug 29, 2008
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
The clothes coming out of washer smell good..after drying have a gas smell
you may want to have a tech on this one you have a gas leak you want to address
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes smell like gas after drying. replaced air vents but did not help.
Sounds like you need to shut the gas off to the dryer immediately. Time to call your local repair company or gas company will come out for free if you have a leak. Good luck and better safe than sorry.
Oct 27, 2009 | Kenmore 63942 Dryer
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
Oily smell on my clothes from the dryer
have you tried tide with fabrezze?
Feb 19, 2009 | GE DBXR463GB Gas Dryer
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Smell Gas.
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
