Question about Kenmore Washing Machines
My washer is one year old I have use it maybe ten times this morning the power was on and the it would not go in to any cycle I then unplug it and tryed again then no power at all it sound like it won'ts to come on and beeps but that all then my wife told me that a error code came up and it was F70 so Idont no whats the problem
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F70 is Central Control unit Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface. To resolve this issue you'll have to:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
Washer vibrates madly on spin, feet are level
This usually happens when the load is uneven.
Dec 28, 2013 | Kenmore Washing Machines
Cannot unlock door
Try first putting the control on 0 , then unplugging power cord for ten minutes, then plugging it bac.
If this does not work try restarting the cycle at any point and leave the cycle to complete, then you try openoing the door.
Sep 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Atf7000es0
Good Morning John, thank you for allowing me to assist you! Here are some simple troubleshooting steps to help resolve this issue:
  • First, reset the unit by either unplugging it or flipping the household circuit breaker.
  • Wait approximately ten minutes and turn on the power for the washer.
  • Next, turn on your washer and select a normal cycle.
If your washer continues to beep, it could possibly have a defective control board or a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Oct 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Won't start?
Good Morning Lisa - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Jun 13, 2013 | Electrolux Dishwashers
Ltf2140e
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
Lights keep flashing with different numbers chane over and
Good Morning Elizabeth - Based on the symptoms you are describing, you may either have a communication error from the main control board, faulty power supply or a potential wiring failure. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to flash. If resetting the power does not correct the issue, I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 27, 2013 | Frigidaire Affinity ATF7000E Front Load...
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is stuck on the wool cycle and won't wash,change cycles
I had the exact problem. I am not sure if this is the fix, but I unplugged the machine over a few hours, then plugged it back in. It stayed off for 20 seconds and then went back to the wool cycle. In frustration, I opened the lid while running my fingers over the cycle select buttons quickly back and forth two times, as I closed the lid, the display cleared and the machine returned to normal, so far anyway. It seemed as if some moisture had gotten in the controls somehow. It was a very humid day and I think that was the problem,after all. My machine is over ten years old, and the only other problem was a clogged drain pump. I used advice from this website to fix that, and saved 300 on repairs at least
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
