Question about Linksys (R) RT41P2-AT 4-Port Wired Router With 2 Phone Ports, Voice Over IP Terminal Adapter, ATT Ca... (RT41P2AT)
Use a wired router for dial-up (NETZERO) connection..
I have an idea... would u be able to connect a wired router to ur computer and use the dial-up internet as ur main inernet source. and if u can, how would u be able to do that???
  • Timmy Buggy May 16, 2008
    im just aking if ur able to do this.
  • Timmy Buggy May 23, 2008
    thank you for helping me! i have a windows xp!
  • 66 Answers
You want to use a LAN with a router that uses a dial-up as a backbone internet connection for your LAN.
This is absolutely possible.
If you just want to share the connection that one computer has, and dont want to buy a router that has a built-in modem, try this
If you are running windows, There is a feature called Internet Connection Sharing (ICS.) It will share the dialup across the network.
Just 1 hookup the router and all the pcs to it. 2 Dialup the machine with the modem. 3 Enable ICS on that machine. 4 Youre LAN is online.
In XP, goto the network connections, and while you have 2 active connections in there (the dialup and the LAN port connected to the router), right click the dialup, goto properties. goto advanced tab, and click on enable ICS.
The other computers should be served IP's automatically and NAT'd out to the internet by the computer running ICS.
(The other computers should be automatically setup to the internet like they should be and connected to the dialup riunning on the ICS (host) computer)
Posted on May 16, 2008
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Wired router connection
Sorry, routers are not my area of expertise. Please try a different expert..Benimur if possible. He's good with this stuff.. or even Ekse.
Benimur
  • 6966 Answers
To my knowledge, yes. "dial-up internet" connotes standard modem attached to a computer unlike DSL modems (non USB) that are stand alone. Therefore the dial-up internet modem should be connected to a single computer. That PC then would have to enable its Internet Sharing for others in the network to access the Internet. This is accomplished by hooking all the PCs to a single network using a hub/switch. The router can perform this function (hub), however, all the PCs in the network would have to use for their Default Gateway IP address not that of the router but that of the PC with the dial-up internet modem. Having said that, it would then be necessary to use static IP adds in all the PCs. The built-in firewall and DHCP features of the router would not be necessary.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 23, 2008
I'm unable to get wireless even though I'm all hooked up with my provider via the modem and a dlink. The only difference regarding the hook up is there is no longer an ethernet cable going to my pc
check the router config settings, may be the router isisnt dialing ur net connection or if u have a static ip n stuff make sure ur default gateway and dns are proper
Jan 10, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have problem my internet provider provide me PPPoE encapsulatio
most of the PPPoE are binded on mac address, clone ur computers mac address to ur router and then dial. this will solve ur problem
Jan 06, 2010 | Linksys WAG200G Router
Netzero connection problem?
A modem is a device that allows you to use a voice telephone line to connect your computer to the internet. If you contact NetZero Tech Support, they will send you a CD to run through the setup. The modem connects to the wall with a standard telephone wire. (The ends are known as RJ11)
Aug 15, 2009 | 2wire HomePortal 100W (1000-400026-000)...
I can'T setup internet on laptop
1st step is to call netzero and as per the setup get it configured.
2nd on your comp go to control panel-network connections- delete all the connections listed their- insert the disc provided with router- run the setup and install it- then connect the usb of router and see if it works..
Clarify ur setup more for more help
Feb 04, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Dial up Modem
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Sep 03, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
No Dial Tone...
first check your phone lines, if they're good call the phone company, you should have a dial tone. netzero only offers dialup so the internet you are using is your neihbors....they didn't lock their router. good luck
Aug 11, 2008 | Computers & Internet
Dial up?
Technically no, not unless the PC where the modem is connected to is used as a Gateway/Share Internet Connection and is connected to the WAN side of the router. However, this arrangement would need a lot of manual configuration and settings on the modem side PC as well as the client PCs.
Alternately, you may be better off connecting the modem PC to a hub rather than a router and set static IP adds on the client PCs.
Jun 24, 2008 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
May 23, 2008 | Microsoft Broadband Networking MN-100...
May 16, 2008 | Microsoft Broadband Networking MN-100...
Linksys (R) RT41P2-AT 4-Port Wired Router With 2 Phone Ports, Voice Over IP Terminal Adapter, ATT Ca... (RT41P2AT) Logo
349 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
