Question about Hitachi 46UX24B/25K 46" Rear Projection Television
Complete loss of audio; video is o.k. Mute command seems to work b/c if mute, the volume icon will change color and tv will bring forth the dialogue; however, the audio is totally silent at any volume level. Lost audio last night during a program. Tried all menu commands and resets but no luck restoring audio. TV is not utilizing wireless speakers, just internal system. Model Hitachi 46UX24B/25K projection color tv app. 15 years old and never previously problematical.
  • Hitachi Master
  • 11,800 Answers
In that case the internal audio amplifier has failed - most likely the power IC has died, it happens. All you need to do is to locate it - follow the speaker wires to the board, next to where they plug in you will find an IC with a radiator = unsolder it from the board then go to a hobby/electronics shot (or search for an replacement online) and get an identical one, solder it back and attach it to the radiator. That is all.
Posted on Sep 14, 2010
My Samsung tv is suddenly muted and I can't unmute. How can I fix this?
The volume buttons have 3 functions... down and up and straight down... that's mute. if that does not fix it go to menu.. the gear icon click on audio, likely we switch to an external sound device like DTS Amplifier...
Tony
Nov 22, 2017 | Samsung Audio Players & Recorders
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
Remote sensor on tv not responding
the problem is the s/w on the tv if you have some solder experience this is easy to fix just repalce the s/w
Feb 12, 2012 | Sylvania LC420SS8 LCD TV
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
My Cousin Put The Volume On Mute And And Now We Cant Turn It Back Up.
Bring your mouse cursor down to the bottom right of the monitor screen. Click on the blue circle with the white arrow in it to reveal your system tray icons. Right-click on the Volume icon. Looks like a speaker. Click on Adjust Volume Properties.
Dec 05, 2010 | Computers & Internet
Sound wont work
If sound won't work while playing videos from Youtube, it could be either of the following:
  1. The volume control of the video itself is in mute or low mode;
  2. The volume control of the headset or speaker is in low mode;
  3. The volume control of the computer itself is in mute or low mode that can be found in the task-bar sound icon; or
  4. The computer itself has no audio device installed.
Sep 06, 2010 | YouTube Videos
Toshiba 47" 1080P LCD 47HL167
Replace the convergence IC and check power resistor for leakage, if values are not exact replace them. Once the parts are in place perform the alignment.
Thank you & post back again if you need additional info.
May 07, 2008 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
