Question about Kenwood Car Audio & Video
Hi, my kENWOOD KDC-237 CD receiver wont save preset radio channels once the ignition is switch off. Please help!!
  • 111 Answers
SOURCE: My Kenwood KDC-241 car stereo loses it memory when
you need to rewire it,it seem like you connect the YELLOW (memory wire)to the ignition line.
You will need to connect it to constant pwr line and the RED to the IGNITION line
Posted on Jan 22, 2010
SOURCE: kenwood kdc 7027
The home position switch from the angle of the front display is not pushed correctly. the problem is mechanical.
If you glue a little tip of plastic between the actuator and the homeposition switch, your problem is history.
In my case, a tip of a little tiewrap did it.
Posted on Apr 30, 2008
SOURCE: ipos nano 3
the aux option doesnt just come up you need to do some funny trick to get the aux cahnel to come up when you going thrugh the standby>tuner>Cd> mode
Posted on Sep 16, 2008
  • 18 Answers
SOURCE: cant seem to get the aux up on my kenwood kdc-237
Its becuase the aux is turned off as default so you have to activate it.
Put the unit into standby mode
Press menu for at least a second untill menu appears and then select the aux option and edit it to either aux on1 or aux on2 or aux off.
Anyproblems and you can download the pdf for free from internet
Posted on Jul 20, 2009
smarthome2
  • 1114 Answers
SOURCE: I have a kenwood radio model kdc-135 and can not set clock or sh
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-135.pdf Here's the manual link from Kenwood and it's on page 13. Hope this helps
Posted on Nov 18, 2009
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
Error message on kenwood KDC-237 car radio
no,it need to go on a machine to have code reset or removed,any car stereo store should help
Dec 23, 2009 | Kenwood KDC-MP235 CD Player
My kenwood 5016 wont take my code mind u i dont no what botton 2 push as have no book on how it works
Kenwood KDC 5016 Code Entry
After switching on the unit the display will show 'ENTER' followed by 'CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
Followed by pressing [DISP/NAMES] button to enter.
The radio will display 'ALL OFF' once the code is entered.
Press [SRC] button to switch on.
The set will now operate.
Nov 10, 2009 | Kenwood Car Audio & Video
How to program radio stations on a kdc-bt742u kenwood
Get to your station then hold the preset button you want to set it to for about 5 seconds, it will beep confirming you have it programmed
Nov 05, 2009 | Kenwood KDC-BT838U Car CD Player
Hi we just bought a used truck with a kenwood KDC-MP4028 cd player. After unplugging the battery we cant seem to unlock the security code.... Im going crazy with out my music, Help!
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
push buttom "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
Oct 18, 2009 | Kenwood KDC-MP4028 CD Player
Kenwood KDC-MP628
try pushing the reset button hold for ten seconds small button after all the preset buttons
May 28, 2009 | Kenwood KDC-MP628 CD Player
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Kenwood car radio code
Did you ever enter a code that you chose? If so, reenter it. If not, call kenwood with serial # and they can tell you the oem preset code.
Oct 25, 2008 | Kenwood KDC-3022 CD Player
Kenwood KDC 237
Can't find your unit on Kenwoods site. But try here.
http://kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Good Luck
Leadispenser
Mar 20, 2008 | Kenwood KDC-135 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Car Audio & Video Logo
147 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
