Question about HP iPAQ RX3115 Pocket PC
My Ipaq RX 3115 had a hard reset. I can see the default files when I connect it to my PC, but an installed program and associated files are deleted. Can I recover these files and if so how? I have Recova but the computer does not recognize the IPAQ as removable drive
  • cnjourdan Sep 15, 2010
    Shelia,
    Thanks for your reply. I figured that was the case but it does not hurt to ask any way. I do back up that file every couple of weeks, but the most recent file are the ones I really need.
    Thanks Again
  • HP Expert
  • 2,973 Answers
Jourdan,
I am sorry to inform you that on a mobile once deleted stays deleted. And a hard reset means that you go back to the factory settings, as if the phone has been just bought. That is they say that one should make it a habit of backing up the data regularly. To make the computer recognize it as a removable drive, you go to settings and under USB you will find an option to show the phone as a removable drive. Else it is recognized as a modem. Change the visibility as Removable Drive or Mass Stotage.
Posted on Sep 14, 2010
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Ipaq rx-3115 stops at align screet after reset
Sounds like u need a replacement LCD
Easily found on ebay
Replacement screens usually come with instructions.
Please note u will need a hollow t8 or t9 tool to open the ipaq case.
Feb 17, 2009 | HP iPAQ RX3115 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
INSTALLING
how much did you pay for this pda? did you buy it recently? Is it brand new or are you the second owner?
Aug 21, 2007 | HP iPAQ RX3115 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Sep 19, 2005 | HP iPAQ H3835 Pocket PC
Charging
If it's completely dead USB probably can't do it at all. There's a voltage threshhold, and USB only puts out about half the voltage needed to get over it. USB usually won't manage when thenbattery's below 30%. Try connecting the iPaq directly to the AC adapter.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
PowerPoint IPAQ 3115
I found a program called PocketSlides that you may want to look into. Doesn't look like there is a pocket pc version of powerpoint. Here is the link http://www.ipaqhq.com/forums/showthread.php?t=10670 Goodluck!
Rx3115 locking up
To execute a hard boot on the iPAQ rx3115, the manual says to "while pressing the two outside buttons on front of iPAQ, press the recessed reset button on bottom." Hope it Helps... Wirzan
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
