Question about GE Freezers
I have GE CB15DRD age 20 lid insulation-seal..complete lid panel needed...where do I find this...and what cost?
  • 32 Answers
Craigs list
Posted on Sep 16, 2010
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
INSULATING A FREEZER LID
you can put insulation over the wires no problem at all, the insulation it would have been is prob styrean. you can buy it in different thickness sheets
Nov 13, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Sub Zero insulation freezing
These units are pretty much manufactured, then the insulation is inserted as a liquid that forms into a solid insulation. Consider the age of the unit for a replacement IMHO.
Mar 11, 2008 | Freezers
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Freezers Logo
44 people viewed this question
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
