Question about Frigidaire FCCW3000F Front Load Washer
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
    President:
  • 1,932 Answers
While spinning the motor rotates really very speed. the belt seems to be intact when you rotate by hand.But when the motor starts running faster if the belt is loose it will start to slip.Please try changing the belt.Each belt have a number on it so please replace with the same size belt.This will solve the problem
Thank You
Posted on Sep 14, 2010
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Well the belt cause a loud noise when it spinning out have to use max spin or clothe are still a little wet
During the spin cycle a loud noise is usually coming from the bearings. If you want to know whether it's coming from the bearings of the engine or the drum, you can remove the belt and turn first turn with the drum and then with the shaft of the motor. If the bearings are bad you can hear it and also feel it if you touch the motor and the drum
May 01, 2014 | Washing Machines
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
I have a GE washer which the agitator and tub do not spin. I can turn both freely by hand. The belt is in tact. During the cycle, the motor just osillates a minute amount in both the clock and counter...
it might be the safety switch under the door.
it is a switch that will not allow the spin cycle to spin unless the door is closed - like when you look in your washer while its spinning and as soon as you open the door the spinning stops until you shut the door again.
if its damaged it will not allow the spin cycle to work.
try look under the lid.
costs around $3.00 put in with a screw driver good luck
aloha
Feb 13, 2011 | GE Washing Machines
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Frigidaire FCCW3000F Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
