Question about Singer Sewing Machines
Trying to found out how to thread the bobbin - Singer Sewing Machines
  • marianne bags Sep 14, 2010
    its is a top loading or front loading, metal or plastic? Look on yuor tube; you may see the perfect instructions. generally, there not much to do just put it in the correct way and pull the thread up with the needle thread.
  • 161 Answers
They usually just pop in; check for a video on you tube so you can see how to load it. Be aware, that bobbins only go in one way, the direction the thread comes off is important ie clockwise or anticlockwise
Posted on Sep 15, 2010
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
Why is my thread nesting on my Babylock BMP8?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Jan 14, 2013 | Sewing Machines
Thread stuck around the bobbin housing on my
try cleaning all that you can out of the bobbin case then try very carefully to bump it backward (opposite) with the hand wheel . Be careful not to knot out of timing. sounds like you have thread in between bobbin case and hook
Apr 06, 2010 | Consew 339RB-3 Sewing Machine
Needle not picking up bobbin thread on Prolectrix 8 stitch
my machine is not picking the thread from down bobbin thread ,i am fallowing the all instruction for threading.
Jul 21, 2009 | Sewing Machines
Bobbin thread getting all nested underneath fabric
I have found that either the bobbin is not threaded correctly or the top is not threaded correctly. Try re-threading your machine. I always sew on a test piece before sewing on my project.
Apr 03, 2009 | PfaFF Creative 7570
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
Mar 21, 2009 | Bernina Virtuosa 150
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Nov 17, 2007 | Sewing Machines
Bobbin thread bunching
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Feb 18, 2007 | White Sewing White 3032
Sewing Machines Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
