Question about HP LaserJet 4600 Printer
We recently upgraded our server to windows 2007 from 2003. I was able to duplex print on my laserjet 4600dn before, but now the properties menu has changed and the duplex unit option under device settings and installable options is "not installed" and it does not allow me to change it to installed. Any ideas?
  • 1,110 Answers
Make sure the printer and driver indicate HP 4600 and not 4650. I have seen these 2 get confused before and the 4650 does not have a duplex option.
Posted on Sep 14, 2010
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
Where is the option to print black and white only (HP 4600dn)
Open the file or image you want to print.Select File>Print>Print Wizard/Tab opens>Select the printer from drop down list>Click Properties tab on the right side area>Below Color Intensity Area>click GREYSCALE PRINTING.
This work for me so give it a try.
Aug 19, 2011 | HP LaserJet 4600dn Color Printer
I have hp3005d printer working fine but can't print duplex ( both sides) printing I am connect through network tcp/ip I have change the setting on the printing properties but still only manual duplex...
Right click on the printer driver icon and select properties. When the window opens, click on device settings tab at the top. Under device settings you will find a section labelled "installable options". Make it that it shows the duplexer installed. This is the most common reason that the duplexing will not function.
Jul 13, 2011 | HP LaserJet P3005d Printer
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
How do I tell the printer to take from the top tray?
Page 63 of your HP LaserJet 4600dn printer manual:
Controlling print jobs: (condensed version) MS Windows
Three settings affect how the printer driver tries to pull paper when you send a print job. The "Source," "Type," and "Size" settings appear in the Page Setup, Print, or Print Properties dialog boxes in most software programs.
Your question indicates that you wish to configure your printer to take from the top tray. That is a "Source" setting. So in the print Setup or Print Properties dialog box, change the "Source" to Tray 1.
Printing by Source means you choose a specific tray
from which you want the printer to pull paper. The printer tries to print from this tray, no matter what type or size is loaded in it. If you choose a tray that is configured from the embedded Web server for a type or size that does not match your print job, the
printer does not print automatically. Instead, it waits for you to load the tray you chose with the type or size of print media for your print job. If you load the tray, the printer begins printing. If you press the printer tries to print from another tray that has the correct type or size.
Kindly vote for my solution if this info was helpful.
Dec 30, 2009 | HP LaserJet 4600dn Color Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Duplex printing from Windows 2003 does not work.
some mnfs drivers require you to web into the copier (type the printer ip into interntet explorer) and turn on certain features like duplexing and finishing options before you can use them in a drop down print property page such as word.
Aug 04, 2009 | Office Equipment & Supplies
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP LaserJet 4600 Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
