Question about Maytag MTB1891AR Top Freezer Refrigerator
Fan in freezer making a very loud buzz and there is frost on the back of the freezer. What should I do??
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 28, 2010
Refrigerator is making a loud buzzing sound in the freezer compartment. We did see a Er FF error on the display. We cleaned out any extra ice/frost buildup and then reset the breaker. The display no...
check your evaporator fan maybe the fan blade hitting edges or the shaft or bushing has damage cause of buzzing sounds apply lubrication or replace bushing but before you dismantle try to off the unit.
Feb 20, 2011 | LG LFX25960ST Stainless Steel French Door...
The fan is running in the freezer constantly and frost is building up on the walls of the inside of the freezer. The fan is making a loud buzzing noise.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Refrigerators
Freezer ajar loud noise
Yes Evaporator fan that has ice accumulation in it. Turn off the unit and leave the freezer open for about an hour or two re-start it and hopefully the frost that built up from the freezer being ajar will have thawed and melted away.
good luck to you!
Jun 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
Frost build up in freezer, makes a buzzing noise.
The problem was fixed by replacing the "bi-metal" device. The fan was making a buzzing noise because it was hitting a build up of ice on the coils and behind the whole back panel.
The bi-metal device was bad and "bulging" out and not performing like a switch. It kept the compressor going all the time and never allowed the freezer to go into the "defrost" mode.
Oct 15, 2009 | Roper Refrigerators
Kenmore Coldspot freezer is buzzing loudly
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure.
Eric
Jul 03, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Maytag MTB1891AR Top Freezer Refrigerator Logo
51 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
